SL/R230: Please explain (like I知 5) key tracks and memory blocks
Old Dec 20, 2020 | 09:05 AM
EdGrimley's Avatar
2009 R230 - SL550
Recently acquired a second R230 2009 SL550 from an MB dealer. It has keyless-go (KG) option and came with 1 key fob which works with doors and in ignition switch but not KG. Dealer ordered 2 additional brand new key fobs (came in bags marked 4 and 5) delivered direct to me from MB parts depot assuring me that they would work with KG out of the box. Of course, now I have 3 fobs without KG. I know how it should work as I have another 2009 R230 with KG which works perfectly.
Based on my reading, I surmise the problem is that fobs 1 & 2 were lost/kept by previous owner and another fob (#3) was acquired. I think that only key tracks in memory blocks 1 & 2 can work with KG. I know I can assign key (tracks) to memory blocks with my DAS software, but I want to understand things before I start tinkering.
Can someone explain precisely what is meant by the terms key tracks and memory blocks in this context and why with each memory block DAS shows there are eight possible key tracks?
Enquiring minds want to know, and all that. Thanks in advance.
Old Dec 20, 2020 | 04:05 PM
pmercury's Avatar
member
CL
here is plenty of info
https://mbworld.org/forums/cl-class-...onversion.html
Old Dec 20, 2020 | 04:08 PM
pmercury's Avatar
member
CL
and here documentation
File Type: pdf
File Type: pdf
Old Dec 22, 2020 | 12:00 AM
BeMyWn's Avatar
SL600
Documentation state that it is applicable for MODEL 215, 220 up to 30.9.02, I dont see R230, or I am not getting it right?
Old Dec 22, 2020 | 06:28 AM
BenzNinja's Avatar
Former Vendor
correct but it was just to show how it works
the info you need is explained in the link
