SL/R230: Trunk partition error fixed
Old Feb 5, 2021 | 01:12 AM
LanceDal's Avatar
06 SL500
Lately, I kept getting the trunk partition error message when tried to open the top. Turned out, trunk partition sensor was bad. The trace on the PCB broke. I removed PCB, unsolder the chip, fixed the trace and everything worked again.
If your sensor is bad, it could also be the chip which you can buy for $4 on Mouser.
I didn’t want to buy a used latch because who know what condition it is in.
here are few pics of the PCB and the fixes
The sensor module
Broken trace fix
If the switch is bad, you can find the part here https://www.mouser.com/ProductDetail...7TXG5D6w%3D%3D
Old Feb 10, 2021 | 04:25 PM
tydriver's Avatar
SL550
good find. Mine gives trouble if anything touches it or the wire harness. I'll have to pull it and check.
