SL/R230: STUCK DVD
Old Feb 21, 2021 | 10:47 AM
ceberus's Avatar
SL 550
STUCK DVD
My COMMAND 6 Cartridge in dash DVD player won't eject or play DVDs. Slots 1 and 2 both have DVDs, but pressing the eject button has the same result. It just turns for a few minutes like it's trying to eject but can't do it. I have tried tapping the player while ejecting, but that didn't work. Anyone dealt with this before? It's very aggravating I would rather change the water pump then fish out a stuck DVD.
Old Feb 11, 2023 | 04:56 PM
JanIDK's Avatar
Delorean DMC12
Same problem. Did you solve this? I inserted a music DVD. The screen says the system is not available.
anyone knows how to solve this? It does nothing, I think the disc is not spinning either.
Old Feb 12, 2023 | 11:15 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Pushing the on off button of a Comand for 5-10 seconds (don't know) is said to reset the unit. A last resort for those in agony is disconnecting the ground cable of the accessories battery in the back. Give it 10 mins or so (don't know).
Good luck!
Old Feb 12, 2023 | 06:23 PM
ceberus's Avatar
SL 550
I had to take out the entire COMMAND UNIT and send it to a shop in California which specializes in removing stuck DVDs. It was quite a bit of work since you have to dis-assemble the center console. Below is the shop I used in California. I highly recommend them if you try this yourself. Best cost (I think around $450), very professional and fast turn-around:
Car Audio Video Navigation Service Center - Hi-Tech Electronic Services (hitechserv.com)
Old Feb 13, 2023 | 03:28 AM
Did they tell you what caused the problem?
Old Feb 13, 2023 | 02:34 PM
JanIDK's Avatar
Delorean DMC12
I have actually an R231 but I was looking for a solution.
I will try this. I hope it works, thanks for the suggestion.
jan
Old Feb 13, 2023 | 03:11 PM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
My CD changer once in a while gets stuck, but when it does, I discovered that tapping on top of the cartridge with the handle of a screwdriver while pressing eject gets the job done. I think this is caused by the cartridge holders not slippering out easy, since when I used an old cartridge, started getting stuck more frequently. so a dry lubricant like graphite or silicone will help!
Old Feb 15, 2023 | 03:43 PM
JanIDK's Avatar
Delorean DMC12
My problem us that there is no eject button, I must select an eject option in the software that is not lit up.
plenty of other media, I might ask the garage during the next service but I do not want to spend a couple 100eds on this.
but thank you all for your help
