SL/R230: Interior CAN Check
One very useful feature on this procedure over the regular diagnosis is that you can monitor the wake-up signals on CAN B. This should help to find power drain issues since CAN wake-up or failure to sleep would cause high consumption. You can also monitor actual values being transmitted over the bus. These values are obtainable on other modules, but this would allow you to see if missing data is due to transmission or reception problems.
Has anyone obtained/made these cables and performed this test or found additional documentation?
The multiplexer accepts that cable on one end and on the other the multiplexer connects to the laptop (STAR system) via RS232 port.
Would you know how to connect to the X30/15?
