SL/R230: Wheel alignment and camber advise
Old Jun 2, 2021 | 04:15 PM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Guys
This is my recent 4 wheel alignment. Would like to know if the front camber is worth buying the camber bolts to adjust it in slightly? Or should I leave it?
Old Jun 2, 2021 | 05:32 PM
Gene Fiorot's Avatar
SL500
You should change them caster and camber. I would not be surprised if you needed a lower control arm bushing. If you do buy the arm with the bushing because you need a special tool to press the bushing in the arm. I went through this with my 04 and before keeping the alignment was a problem as it would change.
Old Jun 3, 2021 | 03:55 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
^this. The front lower control arm bushings only last about 40k before they need replaced.
