SL/R230: profuse leak from ??
is there a way to up load a short video?
in the 2nd picture I am pointing to where its dropping but it's from the unit in picture one
it's just spraying
maybe I can temporarily fix it ?
you know that video was taken before
I ran the engine once more and it was even a bigger flow
Here is a picture of the hose end, the green ring is an o-ring, there is one on each side of the fitting to seal between the housing, fitting, and bolt:
so it's not welded you say?/ it can be removed so the one on the hose can fit instead? am I getting this right?
Here is a picture of an assembly with the hollow bolt, this one uses compression washers instead of o-rings,
While I normally favor buying new (from mercedes) on critical parts, since this is only available connected to a hose that one hopes you NEVER have to replace which lists for $590 and wholesales for $430 https://www.mbdirectparts.com/oem-pa...ine-2303208353 AND since this part can be found on it own used for a 3rd the price https://www.ebay.com/itm/11476414805...8AAOSwezFgdSeG you may want to consider going used in this case.
HTH,
Chris
tab broken on pulsation damper support bracket
bracket repaired
https://www.ebay.com/itm/184845981993?epid=1137167076&hash=item2b09add929:g
5QAAOSwoWdgpSxT
HTH,
Chris
bracket repaired
03-06 Mercedes R230 SL500 SL55 AMG ABC Suspension Oil Pressure Pipe Line OEM
this is better than buying the pulsation damper or would you buy both?
While looking for a pic of the bracket, I did find a diy (for removing the tandem pump) that includes a picture of the bracket (still attached to removed damper so it gives some orientation context).
here is the link to the thread it came from
https://www.benzworld.org/threads/di...-pump.2557745/
HTH,
Chris
Chris
