SL/R230: Stuck in Park can't shift Need help
Old Dec 16, 2021 | 12:25 AM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Need help... car is 2009 SL550 90K miles. This morning was very cold and I can't shift the car from P.
However few attempt I could shifted. Took to my mechanic and changed the new metal lever in the shifter module.
Now something getting weird. Normally need to press brake in order to shift but now no need to push brake pedal and can shift to any gear.
I can drive like this but don't feel safe at all. My mechanic told me it's the solenoid causing this. Can anyone confirm is solenoid ? how many are there ?
Or is it the Trans Shift Lever ?
https://www.ebay.com/itm/12491394509...kaAmrqEALw_wcB
I am not sure what's wrong and what to do at this point. The car shift fine but don't feel safe if accidently push to Reverse since no need to press Brake pedal at all.
Any advise please.
Thanks in advance.
Old Dec 16, 2021 | 08:11 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
The solenoid is in the shifter and is what moves the release lever to allow you to shift out of park. I would suspect that the spring was not properly reattached to the lever and it is not locking the shifter. It might also be that the wrong lever was installed. The are different designs, so make sure that your mechanic had the right one. You cannot swap a used shifter, it is theft relevant and you car will not start with mismatched ECU, EIS, and ESM (shifter).
Old Dec 16, 2021 | 01:26 PM
CharlyE500's Avatar
Thank you. I will ask my mechanic to double check the part. Is this very common thing to happen ? How much would solenoid cost ? and hard to find this part ?
Old Dec 16, 2021 | 02:34 PM
MikeJ65's Avatar
To be clear, the solenoid is energized to release the lever. Since it is not locking in the first place, I seriously doubt it is a bad solenoid. It is actuated by the brake switch, so I suppose it is possible that the brake switch is stuck down. However, since you just did surgery on the shift lever, logic would point to that being the problem.
If you did need a solenoid, it is not offered as a service part, Mercedes only sells the complete shifter. You would have to identify it and try to find some generic equivalent, or get one from a used shifter. If the spring is lost, you should be able to find something that will work.
Old Dec 17, 2021 | 04:30 PM
SocksSL500's Avatar
2009 SL 550; 2022 GLE 450
This is a common problem - plastic part in shifter breaks; repair is not expensive with aftermarket aluminum part.
Old Dec 17, 2021 | 07:24 PM
CharlyE500's Avatar
The problem is now no need push down brake pedal can shift from P to any gear...
Old Dec 18, 2021 | 08:15 AM
cdk4219's Avatar
95 SL600
As above something is wrong with the lever, either it’s broken,wrong one installed, or spring missing.
Old Dec 18, 2021 | 05:59 PM
Keith Noon's Avatar
SL500 R230
...or there's no lever in there at all.
Old Dec 19, 2021 | 10:27 AM
cdk4219's Avatar
95 SL600
He did say initially that he couldn’t get the lever out of park, but after a few attempts it moved. Sounds like something was in there at some point.
Old Dec 19, 2021 | 05:28 PM
mrvedit's Avatar
2004 SL600
If the internal plastic shift lever did break, be GLAD your shifter is not stuck in Park because it is then very difficult to remove the entire shifter.
This video might be useful (my link skips over the useless part of the video):
Old Dec 20, 2021 | 07:54 PM
CharlyE500's Avatar
My mechanic actually replaced the plastic thingy with metal part. However, he said part part was actually not broken. He even showed me the part....
Old Dec 21, 2021 | 07:14 PM
Keith Noon's Avatar
SL500 R230
If he's replaced the plastic lever and the shift lever moves without pressing the brake pedal, he's put it together wrong. It needs to be checked for a feed to the solenoid inside the shifter box. If it has a live feed then the solenoid is faulty. If a faulty solenoid is replaced and the whole lot reassembled correctly, it should work as designed.
