SL/R230: Command system replacement
Old Dec 19, 2021 | 03:23 PM
randsny's Avatar
2021 GLE450
Exclamation Command system replacement
I am considering upgrading my car's stereo with a new Multimedia Receiver (Pioneer DMH-W4660NEX). I plan to keep the Bose amp and speakers and just use a MOST connection from the head unit to the amp. The question I have for folks is this. How does the volume control work? Do you preset the volume with the steering wheel control (max volume) and then use the volume controls of the head unit to adjust the volume within the set limit or do the head unit and steering wheel controls both adjust the Bose amp?
Old Dec 19, 2021 | 04:58 PM
mrvedit's Avatar
2004 SL600
What year and model car are you retrofitting? You posted in the R230 section but show a 2021 car.
Old Dec 19, 2021 | 06:04 PM
randsny's Avatar
2021 GLE450
2007 SL550
Sorry for not being clear.
Old Dec 19, 2021 | 06:14 PM
mrvedit's Avatar
2004 SL600
Your selected Pioneer Head-unit looks top quality. I bought a $180 Head-unit from Amazon and am very happy with it. With an adapter (as mentioned on the Pioneer description), my steering wheel "+" and "-" keys adjust the volume. My head-unit also has a volume control button so that I can quickly change volume if needed. See my post #19 here:
https://mbworld.org/forums/sl55-amg-...004-sl600.html
Old Dec 20, 2021 | 03:58 PM
g0rsq's Avatar
SL500
Your new headunit will control the volume.
The output from the Phono connectors on your head unit will be translated by the MOST converter and the BOSE amp will respond correctly.
Your steering wheel controls will do absolutely nothing.....
UNLESS.....
you use a CANBUS adapter which can connect your headunit to the Mercedes CANBUS. Then the volume controls, forward/Back and telephone buttons on steering wheel will control the new headunit.
Waiting for adapter fascia so I can fit my Pioneer head unit, that I removed from my old SLK, into my 2005 SL500. Hoping the SLK parts will fit the SL500 system
Old Dec 20, 2021 | 04:23 PM
mrvedit's Avatar
2004 SL600
This is the CANbus adapter I used and which seems to be very popular:
Amazon Amazon
I only got the Volume Up/Down buttons working, but I think that was a limitation of my cheap Head-unit.
