SL/R230: RADIO - intermittent operation
Old Dec 22, 2021 | 02:51 PM
micstre's Avatar
2007 SL55 AMG
My radio/CD often does not work at the initial engine start-up. Many times it doesn't work until I've driven to a destination, turned off the vehicle to enter a business, then restart the vehicle for my return home or the next stop. Then it may work on subsequent restarts the rest of the day. The next day, it all repeats. What could cause this? I thought maybe it had to warm up, but I can drive for 30 minutes turning on, then off, then on again and it doesn't work.
Old Dec 22, 2021 | 05:25 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Are you getting a consumers offline message? If your back battery is low voltage it can disable your radio and many other functions.
Old Dec 23, 2021 | 07:18 AM
aeginc77's Avatar
2005 SL 600, 2004 Jaguar XKR, 1998 Corvette, 1975 Porsche 914
I had and have a similar problem. It seems to happen when the car has not been used and the consumer battery has run down. I have found that once the consumer (trunk) battery is fully charged the problem goes away. Another obsveration, the consumer battery runs down quickly - much more quickly than I would have expected My conclusion and solution is to put a trickle charger on the battery.
Old Dec 23, 2021 | 03:54 PM
micstre's Avatar
2007 SL55 AMG
No messages at all. I've heard about this, asked the dealer and the "advisor" said he's never heard of that.
Old Dec 23, 2021 | 03:56 PM
micstre's Avatar
2007 SL55 AMG
I found a jumper on the 2nd battery. It appears to be a connector of sorts for a tender. I've ordered a tender from MercedesSource.com
Old Dec 24, 2021 | 11:58 AM
MikeJ65's Avatar
How old is the advisor, 25? If they have ever had an R230 at the dealership (and I sure other models are the same), they have had the message.
