SL/R230: Command replacement
Old Jan 23, 2022 | 12:34 PM
gwcrim's Avatar
SL63 - R230
Command replacement
I've read all the topics on replacing the Command unit in an R230 that I could find. They've been very helpful. I'm about ready to order a head unit for my '09 SL63. Are there any special features that I MUST have in order for the new unit to integrate with the old system? I know that it should be steering wheel compatible and I sure want a back up camera. But working with the optical system and the amplifier are the most critical points. Any input would be appreciated.
I've been looking at Pioneer mostly. A lot of choices are unavailable due to "supply chain" issues.
This is the kit I was planning on using:
https://www.ebay.com/itm/363452972789
Old Jan 24, 2022 | 03:12 PM
BenzNinja's Avatar
Former Vendor
looks like perfect plug and play
you can get it
if you would get some dash codes (probably not) I can code them out easy
Old Jan 24, 2022 | 03:58 PM
gwcrim's Avatar
SL63 - R230
Dash codes?
Old Jan 24, 2022 | 04:20 PM
BenzNinja's Avatar
Former Vendor
Dash codes?
nothing should happen try it
diag errors I mean in diagnostics, messages
Old Jan 24, 2022 | 04:31 PM
gwcrim's Avatar
SL63 - R230
Thanks. I appreciate your input.
Old Jan 25, 2022 | 08:07 AM
flymetom's Avatar
2011 SL550R
Does this kit allow you to retain the cup holders?
Old Jan 25, 2022 | 09:08 AM
gwcrim's Avatar
SL63 - R230
I believe it does. Sure hope so. As I proceed, I'll take pics and share the experience.
Old Jan 25, 2022 | 10:46 AM
BenzNinja's Avatar
Former Vendor
looks like it does
Old Jan 25, 2022 | 04:36 PM
flymetom's Avatar
2011 SL550R
That would be greatly appreciated. I may follow in your foot steps.
Old Jan 26, 2022 | 08:56 AM
gwcrim's Avatar
SL63 - R230
I contacted the vendor and the reply was that it does retain the cupholders.
Old Jan 26, 2022 | 09:31 AM
flymetom's Avatar
2011 SL550R
Very kind of you, thanks.
Old Jan 26, 2022 | 10:05 AM
BenzNinja's Avatar
Former Vendor
looked like that great for you guys
Old Jan 26, 2022 | 02:10 PM
gwcrim's Avatar
SL63 - R230
I got the console out today. The removal wasn't so bad except that the wire to the cigarette lighter didn't have enough give. I believe the lighter needs replaced now. Of course, that made getting the cup holders out much more difficult. The PO must have been into the console previously as the two tabs that hide the cup holder screws were broken and glued back on. Next up is to get to the upper screws of the radio.
From what I understand, because the clock is set through the Command system, it will no longer be adjustable. ls that correct? Any other items for consideration?
Old Jan 26, 2022 | 02:31 PM
gwcrim's Avatar
SL63 - R230
And just like that, it's out. I used the .pdf files from Benzbits for 99% of the removal instructions.
Now I need to choose a head unit. I don't need sat radio nor GPS necessarily, as long as I can mirror Google maps from my phone. Certainly want a back up camera and an Aux input.
I'm open to suggestions.
Old Jan 26, 2022 | 02:55 PM
BenzNinja's Avatar
Former Vendor
clock can be set by cluster and must be coded to not linked to command with Xentry
Old Jan 26, 2022 | 04:37 PM
gwcrim's Avatar
SL63 - R230
Mr. Ninja, is Xentry something you can help with?
Old Jan 26, 2022 | 06:16 PM
BenzNinja's Avatar
Former Vendor
kinda yes !
So who's used BenzNinja? - MBWorld.org Forums
https://www.benzninja.com
send me a msg on contact form pls
Old Jan 26, 2022 | 07:25 PM
Gene Fiorot's Avatar
SL500
Well !!! Dude you just hit a Home Run meeting BenzNinga. We are in the Club join us.
Old Jan 31, 2022 | 12:52 PM
gwcrim's Avatar
SL63 - R230
Today I ordered the installation kit directly from Spiral Audio. Saved about $100 over the Ebay listing. Also ordered a Kenwood DMX907S from ABT. I had been working with Crutchfield but they ran out. Prices on head units have gone through the roof and availability is thin. Still debating which backup camera to go with.
https://www.spiralaudio.com/index.ph...=722&filter=84
https://www.abt.com/Kenwood-eXcelon-.../p/145073.html
Old Jan 31, 2022 | 01:35 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
I have that bezel and frame if someone wants one cheap. Also, if you want to install in an '03 or '04, I have a nice cut down console trim. Would trade both for a decent console trim or ?? Removed them from an '03 that had been converted by came with a head unit.
Old Feb 2, 2022 | 04:32 PM
gwcrim's Avatar
SL63 - R230
Either a late Christmas or an early Valentine's Day.
So far things are going well. I have the console off, the old HU out, and I've been tearing into the trunk so I can run wires. One area that I have yet to explore is the best way to run a wire from the passenger compartment to the engine bay. Suggestions?
Old Feb 5, 2022 | 01:10 PM
SnBSL's Avatar
SL500
Nice! Looking forward to your successful pics. Should be very cool when completed.
Old Feb 5, 2022 | 02:06 PM
SnBSL's Avatar
SL500
you can get it
Good to know. To expand on the idea, if we were to install a modern head unit with 4 camera inputs, are you able to adjust the code so the steering wheel controls function with the new infotainment screen and switch to overhead 360 camera view when shifter is placed in reverse?
Old Feb 6, 2022 | 03:23 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
https://mbworld.org/forums/sl-class-...mpartment.html
post #4
Old Feb 6, 2022 | 09:15 AM
gwcrim's Avatar
SL63 - R230
I've been making progress, albeit slowly. The winter storm cut our power Thursday afternoon. It's Sunday morning and we're still on generator back up, so my shop is warm but not well lit.
I've been fixing little issues along the way. The console lid latch, the Coke encrusted cup holders and ashtray, the broken screw holes in the radio mount. This was a 57,000 mile car when I got it last summer, but it certainly was not pristine. In addition to adding front and rear cameras, I'm putting a Sirius radio cradle in the cockpit. That means running an antenna cable from the trunk, a power wire, and an auxiliary cord.
I have started fitting the adapter kit for the radio. It's not a perfect fit. There are two tabs on the side that interfere and I had to cut them off. Also there is no accommodation for the two screws that come in from the top to hold the radio in. There are two tabs that would appear to be for locking into holes in the original radio mount but there are no such holes. I may try and make some. Then there's the wiring. The instructions that come with the kit are slim, at best. I've yet to start on that.
This little tab interfered with the original radio bracket.
These tabs look like the should fit into non-existent holes.
