SL/R230: Assisting the pump while closing the top question
Old Nov 9, 2022 | 10:33 PM
jhicks6967's Avatar
Sl500
Hello all, recently picked up a 04 sl500. One of the hydraulic cylinders leaks bad. I’ve kept the top down to enjoy the weather but now it’s time to get it closed so I can repair the cylinder. It leaks too fast and the top won’t close by itself. Is it okay to more less assist the top by lifting it some while the button is being pushed? Not wanting to fully manually do it as I’m worried I’d have to have a computer to manually close the side flaps and need some sort of reset?
Old Nov 10, 2022 | 02:02 AM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Manually assisting the pump in closing the roof is no option in my book. Instead, I would open the bypass valve on the pump and manually reverse the trunk lid and close the roof. Once that is done (see other threads for the how to's), you can let the car take of the flaps and trunk lid.
Old Nov 10, 2022 | 04:11 PM
jhicks6967's Avatar
Sl500
Okay
I’ll do that then. This is my current progress. From my understanding I need to release the pump pressure but I don’t get where I did that at. I see the two screws on the pump itself but the vid I have it shows another screw which I don’t see on my pump. After that it seems I need to release the two side brackets with the Allen wrench but they won’t budge at all. I’m lost lol
Old Nov 10, 2022 | 04:43 PM
Tom Manning's Avatar
2005 SL 500 R230
Here's the official MB procedure in the pdf.
You do have the screw:
The tubular frame locks open easily clockwise IIRC - you're probably trying to turn them the wrong way. Only gentle torque required here.
Keep at it!
Old Nov 10, 2022 | 07:27 PM
jhicks6967's Avatar
Sl500
Thank you so much. I tried turning both ways and no luck. I’m wondering since I have the trunk popped in the backwards position instead of flipped forward maybe that could be why the bolts won’t budge ?
Old Nov 10, 2022 | 08:25 PM
2005 SL 500 R230
The boot has to be open in the forward position, then the roof has to be moved to the load assist position, as per the instructions in the pdf.
Old Nov 11, 2022 | 01:47 AM
IIRC the unlocking of the tubular frame is done by turning one side clockwise and the other side anti clockwise. In my car that does take a bit of effort and I think I took it in steps so as not to put friction on the tube and locks. Make sure the bypass is open.
Old Nov 11, 2022 | 02:58 PM
What time zone are you in? I might be fun to try to help you via a WhatsApp video connection.
Old Nov 11, 2022 | 05:38 PM
jhicks6967's Avatar
Sl500
Well
we got the top closed for the most part. The front windows won’t fully close as I assume something is off or not being told it’s closed without a pc. I’m impatient and snapped one of the rear flap rods. I’m hoping to find a part out to replace that broken piece.
Old Nov 11, 2022 | 06:29 PM
2005 SL 500 R230
You followed the instructions in the WIS? Good result. You might be able to fabricate a bolt for that broken pin on the flap.
If you've had the battery disconnected, the windows always require a reset by holding them fully up for a few seconds until all four close fully.
Old Nov 11, 2022 | 09:20 PM
jhicks6967's Avatar
Sl500
Sadly and stupidly I tried to bend them by hand to make them move. I was irritated and impatient. Hoping I haven’t done too much damage. I’ll have to make a bolt or find a part out.
Old Nov 12, 2022 | 05:37 AM
Added info for all: (un)locking the tubular frame locks is of course done with the provided hex key. On the left side, open by turning anti clockwise. Close by turning clockwise.
On the right side it is the opposite.
In other words, with the hex key facing upward, on both L and R side, pull to open and push to close.
Old Nov 25, 2022 | 10:20 PM
jhicks6967's Avatar
Sl500
Just ordered a used set of flaps, motor and all lines for said setup. Tried to make a bolt for the one I snapped but the way it’s made figured was best to get replacement. Once it comes in I’ll follow the procedure and manually close the flaps. My question is where exactly is the control box you have to jump power to? I assume trunk but where ?
Old Nov 26, 2022 | 09:35 AM
cdk4219's Avatar
95 SL600
Would have been easier to fix the leaking cylinder than having to do all of this and still fix the cylinder?
Old Nov 26, 2022 | 01:02 PM
jhicks6967's Avatar
Sl500
Probably so but that’s what happens when you get inpatient and stop caring.
Old Nov 26, 2022 | 02:40 PM
cdk4219's Avatar
95 SL600
Yes both of those things with these cars will lead to additional costly repairs.
Old Nov 28, 2022 | 05:59 PM
jhicks6967's Avatar
Sl500
Oh for sure. For now on I’m having the wife help me out and keep me calm while working on it 🤣. Next up is fixing the crash damage from hitting a dog.
Old Dec 7, 2022 | 02:33 PM
jhicks6967's Avatar
Sl500
Some progress made. Installed new flap assembly, also installed a new throttle pedal unit. I removed the leaking top cylinder and will be sending it out to have rebuilt. Then I’m hoping all will be good to go.
Old Dec 30, 2022 | 08:56 PM
jhicks6967's Avatar
Sl500
I finally received my rebuilt cylinder and installed it. Now the top is working correctly woohoo. Thanks for all the help everyone. Next will be diving into the shift lever. At times it’s hard to get it out of park. Brake lights work and heat it click so I figure it just be the lever.
Old Dec 30, 2022 | 09:09 PM
2005 SL 500 R230
Probably it's got a hairline crack which allows it to work, in a fashion. When it breaks, you'll be stranded.
'Preventative maintenance' never resonated so pointedly.
Old Dec 30, 2022 | 10:07 PM
jhicks6967's Avatar
Sl500
Thats what I figured. I’ve read their are a few different lever sizes ? So I guess I need to research more and figure out which mine is so I can get it ordered.
Old Dec 31, 2022 | 06:08 AM
cdk4219's Avatar
95 SL600
I believe the kit I got came with both levers in case. Not sure if they provide that anymore.
Old Dec 31, 2022 | 04:41 PM
jhicks6967's Avatar
Sl500
ah okay. Started the process of removing everything to see what lever I have. I’m stuck at this point lol. Have the 3 bolts and 2 screws removed. But the bugger won’t come out. I’ll have to do some research tonight at work to see how to do it without breaking stuff like I did before.
Old Dec 31, 2022 | 06:36 PM
2005 SL 500 R230
If you're going to do it all from the top, then you have to cut the cross brace. There's no other way to get it out.
You can glue it up later or just leave it - the console is plenty strong with it cut either sided.
Once cut, wiggle it up and out gently then slip off the retaining clip that holds the selector rod. Replace the clip with the new updated design upon reassembly.
Old Dec 31, 2022 | 06:54 PM
jhicks6967's Avatar
Sl500
Outstanding thank you. I for sure don’t mind cutting the cross brace at all. I can always fab a new one from metal later. Thank you !
