SL/R230: Strange ABC issue
Old Nov 29, 2022 | 06:13 PM
Clavoe's Avatar
2033 SL500
Strange ABC issue
My 2003 SL500 raises itself then drops every 9 minutes while parked. I cannot tell if it does this while driving but definitely if running while parked. Any ideas as to what may be causing this?
Old Nov 30, 2022 | 01:50 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R230 forum...
Old Nov 30, 2022 | 06:02 AM
zuhow's Avatar
SL600, E320-4M
I think you have an issue with the rear SAM, pull it out and look for corrosion (green and crusty) on the circuit board
Old Nov 30, 2022 | 09:05 AM
Dr. Plastic's Avatar
2005 SL500 & 2021 Jeep Willys Gladiator
What zuhow said. I have read there are some issues with water intrusion from the back window/roof seals draining and getting water in the rear SAR causing corrosion and probably other issues down the line. Also check the ABC controller. Re-seat all connectors if you can. That is known to fix connectivity issues. Do you have any codes (for the ABC) stored in the malfunction display ?
Old Mar 3, 2025 | 09:24 AM
wfooshee's Avatar
2007 Jaguar XJ8L, 1999 Miata, 2003 Yamaha FJR1300
got the wrong thread somehow, must have scrolled out of what I was replying to.
