SL/R230: Could a throttle position sensor problem be linked to a flat consumer (rear) battery.
Just wondering whether a throttle position sensor problem could be caused by a flat or faulty
I have had the throttle position sensor problem before when I had no issue with the consumer battery.
However a friend suggested that they might be linked.
thanks
Gerard
If the TPPS overshoots, it will go into limp mode and reset when you turn the car off and on again.
It's not related to a low battery.
