SL/R230: Wheel offset question SL65
Old Dec 11, 2022 | 03:32 PM
427shark's Avatar
05 SL65, 05 CL65, & 08 CLK63
Anyone with a 65 running an 11" wide rear wheel with a 305 series tires ? Did alot of research and can't get a definitive answer regarding offset. The wheels I'm looking at are 19x11 with a 37 offset, can anyone confirm fitment ? Thanks
Old Dec 11, 2022 | 03:59 PM
Dr. Plastic's Avatar
2005 SL500 & 2021 Jeep Willys Gladiator
You can plug in your OEM fiment and then try different combinations to get what you are looking for
Wheel offset calculator
Old Dec 11, 2022 | 04:08 PM
Your stock offset is +31mm. That info is listed under your technical data in the owners manual. I plugged your info in the calculator at this link
https://tiresize.com/wheel-offset-calculator/
Old Dec 11, 2022 | 04:46 PM
427shark's Avatar
wow thanks, this tool pretty much takes alot of the guess work out of it. From what I was reading seems like the oem front offset is 32 & 35 for the rear ? Your saying they are both 31 ?
Old Dec 11, 2022 | 05:19 PM
SL65 OEM offset is as follows: front offset is +30mm, rear is +31mm.
Old Dec 11, 2022 | 06:06 PM
427shark's Avatar
ok thanks
Old Dec 11, 2022 | 11:32 PM
drlc01's Avatar
2005 SL65 AMG, 1987 560SL
Let us know which wheel/tire combination you end up with.
Old Dec 12, 2022 | 05:51 PM
Billro's Avatar
SL65 AMG
Dr Plastic is correct about the SL65 OEM offsets and that is for 8.5" wide front rims and 9.5" rears. I replaced some aftermarket rims on my car with stock. The rims I took off were Mandrus Milenniums 8.5"and 9.5" but with 25mm offset and they fit fine.
