SL/R230: Exhaust Options?
Old Jan 28, 2023 | 09:24 AM
Bdevil82's Avatar
2011 E350 4Matic Wagon 2002 E430 2004 SL500
Exhaust Options?
Understanding exhaust tone is a personal preference, I'd like to massage little more growl from the SL, not looking for a cat-delete, straight pipe obnoxious drone. Interested in hearing what others here have done and how they have liked it, e.g. resonator delete and keeping rest of the system stock. Additionally, any users of any of the SuperSprint components?
https://www.supersprint.com/ww-en/su...30-sl-500.aspx
EDIT: Upon further study it appears stock system does not have a traditional resonator.
Old Apr 8, 2023 | 07:43 PM
Blaz's Avatar
CLS 55 2006, SL 500 2006, CL 500 2013
Hi, I'm looking for the same...any progress Bdevil82?
Thinking to delete resonators (or cats without 02 sensors), which are sitting after cats...
Old Apr 8, 2023 | 10:09 PM
aegea's Avatar
2004 SL500AMG, 2003 SL500 USA
There are 2 AMG exhaust options. One is performance, and the other is more throaty.
Old Apr 9, 2023 | 10:54 AM
Blaz's Avatar
SL 500 w/t M113 engine stock exhaust...
So,... one option to remove silencers before X-pipe or just replace rear mufflers with AMG SL 55 version....right?
Old Apr 9, 2023 | 11:22 AM
aegea's Avatar
AMG mufflers have dual tips.
Old Apr 10, 2023 | 10:05 PM
Hary Gahtoe's Avatar
R230, C5 Corvette Convertible, Audi Allroad, Lexus RX350, AE86 Hachi Roku
If you cut the secondary cats your factory tune will suffer but it will be louder. Not to mention The fuel stink smell
A 5L SL could make the most power and sound louder but still somewhat refined by leaving the secondary cats and adding better flowing cross over section to remove a crippling restriction the factory hurt the performance and sound levels and also add a set of low back pressure mufflers
Old Apr 10, 2023 | 10:17 PM
What the problem is with the exhaust system is one side of the exhaust at the merge is one pipe is crushed in half. Fixing it with a good quality cross over will improve the sound and improve performance
Old Apr 11, 2023 | 05:21 AM
Blaz's Avatar
Thank You, Hary for proper answer.
I see now.
So, basically i need nicer x pipe, then connection tubes till rear mufflers.
Because I would like to look stock, not quad pipes stickin' out,
I've found these in mine neibourhood....
Cheers
Old Apr 13, 2023 | 07:15 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Hi There .
Your car has plenty of grunt from the exhaust, its just silenced via the 2 rear back box. If you want some fun and have the most amazing noise when you are feeling good, I would recommend just using electric cut outs, they are cheap work, on a push of a remote, pretty simple to install and then you can close them with the remote and all is silenced once more !
Here is the install to help explain:
Old Apr 14, 2023 | 01:11 PM
[QUOTE=A1EK;8758813]Hi There .
Your car has plenty of grunt from the exhaust, it’sjust silenced via the 2 rear back box. If you want some fun and have the most amazing noise when you are feeling good, I would recommend just using electric cut outs, they are cheap work, on a push of a remote, pretty simple to install and then you can close them with the remote and all is silenced once more !
I get the direction with the cutouts. Sounds different. They could also be tied into the muffler for an A-B style sound with a direct thru flow internal pipe
TBH; for all the time and money I would’ve fixed the terrible choking exhaust issue of the X pipe directly upstream. It is losing HP/Tq the motor desperately needs and can also aide in a decent quality sound enhancement for whatever you choose behind it
Old Apr 15, 2023 | 08:39 AM
Blaz's Avatar
I strongly agree Hary;
it just doesn't look right, somehaw pressed together, I saw that extra bit yesterday, car beeing on the hoist...
Old Apr 18, 2023 | 01:52 PM
Bdevil82's Avatar
To me, the SuperSprint X-pipe does not look much different than the stock setup. Has anyone actually installed the SuperSprint and how were the results?
Old Apr 18, 2023 | 04:57 PM
g0rsq's Avatar
SL500
My question is why did Mercedes do this to the exhaust if it looses HP and Torque?
They could have fitted an X-Pipe, or made the system more free-flowing, but chose to do this instead?
Love to hear any results of a modification to the weird join...
Old Apr 18, 2023 | 10:39 PM
ParsleySL500's Avatar
SL500
My guess is that MB sectioned the pipes with relief cuts and then joined them rather than just crushing two pipes together.
