SL/R230: sl500 R230
sl500 R230 -06
![Angry](https://mbworld.org/forums/images/icons/icon8.gif)
Hej! jag har problem med att starta bilen från ewm start stopp button,..,med nyckel fungerar det ok och bilen startar,,,,när jag trycker på start på shiftgear så går bara injection on, but no start
finns det någon proffs som kan ge mig ide
tack
tack
From Google translate I think you are saying that the engine won't start from the button on the gear stick but will start with the key in the switch. This is often caused by a bad battery in your key.
I had both of my batteries replaced recently. The front battery of the car uses the key "switch" in the dash. The push button one on the shifter uses the one from the trunk. The shop gave me a bad one and not very many things would work that used the back battery, including the push button start, BUT it would start if I stuck the key in the dash and turned it.
Just something else to consider checking, trunk battery may be low.
