SL/R230: r230 alarm disabling
If the internal batteries in the alarm are really corroded, it might have already shorted out and blown the fuse. It's not a big job to remove the wheel well and pull the plug if you want to be sure. From memory that module has switched power constant power and ground; I don't know if both hot feeds are supplied from that fuse.
