SL/R230: Options for mating used EIS shifter and ECU to the 722.9 conductor plate
I got the car and surmised that the best option was to purchase a used but matching key, EIS , ECU , and shifter from. The same model year car. I installed those and the car started right up. Putting it in gear does nothing, the shifter shows what gear it’s in, but no forward or reverse gears. The pump is operating and trans fluid isn’t burned.
I was reading another post about someone doing the same used part swap in a w211 (he lost the key) with a 722.9 as well, and the same thing happened to that car ( transmission worked fine before ) I believe that’s the problem with this sl500, and was wondering what my options are. I have the original EIS ECU and shifter , but it was suspected that the shifter may be bad from the Mercedes dealership,
What do you think the options are for this? Car is rough, but surprisingly the top works, the suspension works and has 63,000 miles on it. The engine runs very well, and it’s a shame to part it out, and not worth much if it doesn’t go in gear. I’m pretty sure that the problem is the non matching DAS parts
https://www.benzworld.org/threads/ca...#post-18398443
You may find someone who can code it for you, but they need access to Mercedes servers (or data from servers) to get correct coding, now for the car that was the downer for the replacement parts.
I am having issues with the shifter in my CLK at moment, and best option seems to get it repaired. Not sure this is possible for SL shifters but do a search for the module number and see what you can find.
I bought a new conductor plate a few years ago so they're still available, or were then, and not too expensive, but the only issue is you will need it for the VIN of the wreck from which you got the other parts. That's obviously an issue now.
Isn't it possible to order a key for the original car?
reprogrammed a new key for the car.
The bill was $1200 or so, and it still wouldn’t crank. If I remember the key worked in all but the crank position, and the service order from the dealer said they suspected the shifter to be the culprit.
At that time, I wasn’t aware of the fact that the 2005 cars had 722.9 transmissions, and that the conductor plate was linked to the DAS.
i would guess that either the technician didn’t program the key correctly, or the shifter has faulty parts or cold solder joints as he said. My initial solution was to purchase the used matching set of DAS parts to get the car running, I will have to inspect the shifter for faulty joints, and hopefully I can put the original parts back in.
It is possible that some prior owner already replaced the immobilizer trio. If so, a dealer programmed key would not work and that may have been the problem all along. That would be the easiest solution, just an aftermarket key, reinstall the old trio, and you are good to go.
The second option is to diagnose and repair the original issue with the immobilizer. If the key turns, you can check drive authorization in the ESM and ECU and determine where the problem is. I don't think this is the typical shifter solder joint issue as that does not affect the immobilizer functions, just the shifter position reading. A bad EIS can also sometimes be repaired (or cloned). The advantage of this approach is that each of the components is easier to remove and send in than the conductor plate/TCU. Also, the cluster should read mileage without additional work on it.
If you stick with the replacement components, the TCU can be virginized and relearned to the VIN. You might talk with a couple of independent Benz shops to see if they can do it or if they 'have a guy'. There are several systems that will do it, but you might not have anyone in your area. Of course you can remove it and send it in, but that is a bit of a project. You will also have the mileage issue in the cluster, but since mileage won't be actual and it is a bit of a beater, that might be something you just want to live with.
The key must have turned in order for for ignition to happen. It know it wouldn’t crank with the key. I didn’t check for codes. I guess the next step is to reinstall the old stuff and look for the specific issue. I would guess the no crank could be in the shifter?
One of the symptoms is no crank from the engine.
Even after clearing codes in the TCU and ECM, there is still no crank, and the stored code in the ME97 (engine ECU) needs to be cleared before it will crank.
I would have to rule out the wiring, as it starts right up with the new stuff in there. Quite a contraption to stop thieves, I seem to spend lots of money and time securing my belongings and dealing with things that are securing my things. Locks , fences, security systems, housing things indoors for theft prevention, and now this.
in the ETC P240C
There was a code in the CDI 2, but cant remember what it was. Might have just been a message, as it just said check codes in the ETC.
Needed clearing before able to crank the engine.
No DTC's reported on the dash
I doubt the shifters are the same, but the CLK shifter (part A2032679024 containing ESM A2095452232) is part of the DAS system, so used part can not be fitted, but I have found a specialist in Bulgaria who claims can supply ESM that will work.
My guess is he virginises it, and by fitting a virgin ESM it self adapts to car. (WIS ASRA states no coding necessary when fitting new ESM!).
in the ETC P240C
The 203/209/211 shifters resemble the R230 (and 215/220) ESM, however they are not a part of DAS. The 215/220/230 platforms have DAS in the ESM, but 203/209/211 platforms use an ESL as the third DAS component. All of these shifters use the optical pickups to read lever position and all are subject to the P1856/P240C issue because of bad soldering. Basically, the 203/209/211 ESMs are a simplified version, handling only sifter functions and not the immo functions.
Yes you are correct. my typo.
I will post back when I get a resolution.
