SL/R230: Will it say if you have put to much engine oil in the instrument display?
I wish you could get a dipststick for the engine oil that is not only to be used to check the oil level but that can be left in the dipstick tube.
I wish somebody could produce a engine oil dipstick that can stand in the oil tube.
elMacko. You know you can buy the engine oil dipstick "tool" for about $20 - $30. Check the picture below.
This dipstick is from pelicanarts
Dipstick tool that can not be left in the tube. Just to check your engine oil and then remove.
What I did, I found in a junk yard an old Mercedes E-430. Took the dipstick for $5.00. Then when I filled the engine during an oil change, used a wire and measured the right oil level....then figured my junk dipstick was 2" shorter...So I cut it near the top, crimped a small SS tubing in both ends to produce the right depth and bingo!
