SL/R230: Help s69/1 code
Usually, the failure to close the frame locks (and pull down the front of the trunk) is caused by low fluid, but it can be internal bypass in one of the four cylinders on that circuit - front latch, frame locks, trunk lift.
You should always be able to manually lock the frame locks as well as the front lock as long as the pump bypass is open.
I would do the following: open the trunk and open the pump bypass, lock the two frame locks manually, pull the roof back a few inches and make sure that the front latch is open, push the roof back to the header and manually latch it. Make sure that the pump has enough fluid, close the bypass and try to open the roof. Fluid doesn't evaporate, so if adding some 'solves' the problem, you need to look for the leak.
With the roof closed against the windshield header, check the status of the S69/1 switch with your scanner, not codes, the actual value of the switch. It should be Recognized. Pull the roof back a few inches, recheck the S69/1 status, it should be Not Recognized.
While you should always read the fault codes, don't expect a lot of help from them in diagnosing roof problems. Many issues that arise will either not throw a code, or will throw a code that may be a symptom rather than the root cause.
