Command Unit Malfunctioning
While using the single DVD player to play MP-3 music files on the player the sound stops and starts intermittently and then an error message appears " CD ROM error or No CD. The DVD hesitates to be ejected, but finally came out. I reinserted, the files loaded and it was playing. However, later the whole same scenario started again. This is my second command unit for a 2005 SL500, it was replaced a good number of years ago with a used unit. I'm thinking it needs to be replaced again, but I wanted to pull the fuse to power it down to see if the unit resets itself. Does anyone know where the fuse is located, I do have one fuse chart for the engine compartment fuse panel but can't identify it. Is this fuse located in another panel? Thanks in advance for the help.
