SL/R230: Ac blower issue fixed
Old Jul 8, 2023 | 09:52 PM
Gantalope's Avatar
2006 sl500
Recently the ac blower in my 2006 sl500 had stopped working. Initially it was intermittent but eventually became permanently stopped. I had read about blower motors going bad or the resistors corroding. So I took mine apart to inspect it and found no signs corrosion or damage to the blower so I cleaned it all up and went to inspect the cable that connects to unit and noticed that brown wire had started to slide out of the connector housing causing high resistance which started to melt the connector. Reseat the the brown wire which solved the issue. Just something to look out for.
