SL/R230: HomeLink garage door opener
Old Jul 12, 2023 | 11:24 PM
Gintonics's Avatar
Merceds-Benz SL500
Has anyone had an issue programming the onboard garage door opener for an R230. Mine simply flashes yellow and never learns a garage door code
Directions I am following:
1. Hold desired button and garage door opener button until light on the HomeLink/rearview mirror changes flashing from slow to fast.
2. Once light starts flashing fast the unit is programmed.
Problem is the system does not seem to accept the garage door opener code as the light stays flashing slowly
Has anyone else encountered this, and found a solution?
Old Jul 13, 2023 | 03:13 AM
superswiss's Avatar
2019 C63CS
I can't answer your question specifically for the R230, but there are a couple of common things to follow with Homelink.
  1. Go to https://www.homelink.com/program and confirm the specific steps for your car and garage door opener.
  2. If you have a Chamberlain/LiftMaster garage door opener manufactured after 2011, then you will need a repeater, because the Homelink in your car is too old to support the new Security+ 2.0 protocol. https://www.liftmaster.com/homelink-...OMELINK+RPTRMC. Other garage door openers may have the same issue.
Old Jul 13, 2023 | 08:18 AM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
I had the same issue on my W212 and the repeater device purchased from Amazon solved the problem.
Old Jul 14, 2023 | 05:16 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
I have an old chamberlain garage door opener that wouldn't communicate with the car. I bought a 4 channel receiver-transmitter set (China) for next to nothing. Hooked it up in parallel with the connection to the push button on the garage wall.
Your car's home link has three push buttons. I hooked up a timer to the receiver; button #2 fires up the main garage lights for 3 minutes, button #3 switches them off before the timer runs out. Very convenient when backing in at night!
Old Jul 15, 2023 | 08:28 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Homelink repeater (linked above) solved this problem for me.
Old Jul 20, 2023 | 08:24 AM
ajluzi1957's Avatar
2008 r230 SL550
New member here with a new to me 2008 SL550, This worked for me also and I thank you for the help! Couldn't understand why it would never work
Old Jul 27, 2023 | 08:19 AM
Gottaloveit's Avatar
05 SL500
Garage door opener
I just programmed mine, no problem. I have a chamberlain. First hold you door opener 3 to 5" from mirror. Press both buttons at the same time, your home link will flash slowly at first, then rapidly, let go. Now press the learn button on the opener inside the garage. You have 30 seconds to get back to the car and press the same button again until door closes.
