SL/R230: Vario roof flap actuating cable
Old Sep 7, 2023 | 03:51 PM
flyslowlow's Avatar
2003 SL 500,1986 420 SEL, 1966 250S
Looking for some help and wisdom. The rack ( of the rack and pinion ) on the drivers side of the car is attached to the control cable. Unfortunately the rack on the passenger side of the vehicle detached from the control cable and the cable slid inside its sleeve and I am unable to pull it out and reattach the rack. Any advice on how to get enough slack to pull out the control cable?
Old Sep 7, 2023 | 05:49 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
A picture might help. I am not an expert but having a hard time visualizing your issue. Also model year helps on your r230.
Old Sep 7, 2023 | 05:55 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Take it off at the motor end and push it through. I'm not sure how much luck you will have reattaching the end, but that will at least give you access.
