SL/R230: Roof issues not resolved
I'm not sure how you would see voltage at pin 8. Pins 7&8 and 11&14 are just the motor leads from each rear motor. With the plug unplugged from the roof module, there should not be any voltage nor continuity to ground on these leads. Double check that reading. If you really do have voltage there, you need to trace the wires and figure out why.
Ok back probing yelled no response while plug was in RVC except voltage levels on 10 & 12 stayed consistent, i was able to operate the windows from the plug with my power probe ( so no short from plug to windows )…. I must have probed wrong pin on my previous post showing power to pin 8. …. I’m not sure if matters but I can’t operate windows with PP while it is still plugged into the RVC .
yes I did replace it with another one with the same out-come ,
Just curious could my rear SAM be my issue?
Well it’s not the SAM ;-(
