SL/R230: Broken Convertible Top Shelf Cable Holder?
2006 CLS500, 2005 S430, 1998 SLK230
I was having issues opening my convertible top on my 2011 SL550 and after doing some diagnostics noticed the reason is because my top shelf does go up when I'm opening the top, it's because the plastic holder piece that is supposed to hold the cable in place is broken, seen in the sample picture below right above the ring terminal. Mercedes seems to only sell it as a complete cable assembly, anyone know where I might get just that plastic bracket?
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
I have some that are professionally printed in nylon on HP MJF printers. I will PM the details.
Also, make sure that the gas strut is strong. Otherwise you might continue to break the ends.
Sent you a PM, it wasn't the end piece that broke off, it's the middle plastic piece right above the ring terminal in the picture, the part with like 3 grooves on it.
I believe that is still available as a separate item, P/N 230-790-11-77.
If it is obsolete, let me know and I will model it and order a few.
I think that's it, thank you!! Just curious what diagram did you find that part in? I was looking forever through the parts diagrams and couldn't find it
