SL/R230: Is this normal - Alternator?
Old Nov 22, 2023 | 11:05 PM
Das Geld 2's Avatar
SL55, S500
Gentleman,
I have this odd issue, when I sit in the car with the engine running and with the windows up, if I flick both switches up to indicate closing. The voltage of the car will drop from 14.1 to 13.8 and as low as 13.3 and the lights on the dash will flicker/dim as well as an rpm surge of say about 100 rpm.
This does not happen with normal window operation. Only the above.
Is this signs of a failing alternator? voltage regulator or battery?
Old Nov 23, 2023 | 07:36 AM
JettaRed's Avatar
Veteran: Army
I only heard clicking. Didn't see what you were talking about.
IF you try to raise the windows when they are already up, there is a big draw on the alternator. Is this something new that has developed or did you not notice it before? How long has it been happening?
Old Nov 23, 2023 | 08:58 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
I see the dimming, quite noticeable, but I have never really noticed the dimming my car so will look. The voltage should sit around 14.1V and dip down with rear heater and windows etc, the voltage regulator will then so its job to regulate the voltage. So long as your car is putting out 14.1 V then your car alternator is okay. I will check my car an see.
Old Nov 23, 2023 | 06:46 PM
Das Geld 2's Avatar
SL55, S500
Notice the illuminated lights dimming. Ok, I guess that makes sense. I recently noticed it when I hit the window button in the wrong direction.
Ok, let me know. Thanks!
Old Feb 6, 2024 | 09:35 AM
HLG600's Avatar
2009 SL63 AMG
@Das Geld 2 I noticed this for the first time a few days ago.
Troubleshooting led me to discover that the rear / consumer battery was in very bad shape.
No warnings, just some odd quirks with the car. Removed the battery and it took a full charge without issue, but when tested, showed 6% health remaining.
New H6 AGM went in and all of those quirks I was noticing went away.
There still is a slight flicker when holding both window switches up past closed, only noticeable if looking for it. I'll take this as normal operation if both batteries are now perfect and the car is showing a steady 14.1 - 14.3 V while running.
Check that consumer. I was surprised it could be that bad without throwing all kinds of warnings / errors.
Old Feb 6, 2024 | 09:58 AM
Das Geld 2's Avatar
SL55, S500
Thanks H!
Good to know, I keep mine on a CTEK year round.
I am planning to get new batteries for the upcoming spring season.
Which brand did you go with? Optima?
Old Feb 6, 2024 | 10:36 AM
JettaRed's Avatar
Veteran: Army
Many people have posted that the battery from the dealer is competitive with the auto parts store. But, before reading that, I got mine from FCP.
(NOTE: These are batteries for my 2015 SL400. Those prices were from 2022, just two years ago. Today's prices for the big one is nearly $100 more! Inflation? Nah, it's under control.)
Old Feb 6, 2024 | 10:49 AM
JettaRed's Avatar
Veteran: Army
It seems the consumer battery for the R230 SL-Class is cheaper than the R231.
Old Feb 6, 2024 | 11:12 AM
HLG600's Avatar
2009 SL63 AMG
Thanks H!
Anytime!
I went with a Duralast Platinum H6 AGM. Meets the exact factory specs and is available at a local AutoZone.
OE Genuine wasn't that much more expensive, but the warranty on the Duralast is better / easier to deal with.
@JettaRed Considered that Odyssey option (I've used their batteries before and liked them) but decided against it after realizing the specs are off from factory (720 vs. 760 CCA and 69 vs. 70 Ah).
I realize it's only slightly off, but given the BCM and general complexity / sensitivity of the electrical system, I just didn't want to deviate from factory spec in any way.
Old May 2, 2024 | 10:28 PM
Das Geld 2's Avatar
SL55, S500
Picked up and installed a new front and rear 211/229 from the dealer. Better prices than auto zone.
Flickering is light but I'll take it, 3/24 production date on the rear.
Old Feb 21, 2025 | 04:20 PM
yovenim's Avatar
just looking
Gentleman,
I have this odd issue, when I sit in the car with the engine running and with the windows up, if I flick both switches up to indicate closing CBT test training in Milton Keynes. The voltage of the car will drop from 14.1 to 13.8 and as low as 13.3 and the lights on the dash will flicker/dim as well as an rpm surge of say about 100 rpm.
https://youtu.be/ZjWqn80cgCE
A voltage drop from 14.1V to 13.3V when holding both window switches up suggests a high electrical load. It could be a weak battery, failing voltage regulator, or poor grounding. If the alternator isn’t compensating properly, it might be struggling. Check battery health, alternator output under load (should stay above 13V), and grounding connections for corrosion.
