SL550 2007
Highly suggest you open your private msg to recieve info. 2. Being that this is a new year gonna do what was told to me when I first came to the forum. Check the interweb, and other sources, however as stated this ahould help your cause:
See #2 video
https://www.benzworld.org/threads/he...trunk.3117736/
R,
2Merks
Unfortunately, if the blade key is not doing anything, there are not great options. When I encountered this issue on a 2003 SL500 a few years back, I had to remove (i.e. break) the center rear brake light lens and manually toggle the lever with a flat blade screwdriver.
This was after 1) a automotive locksmith tried and 2) I let it soak with penetrating oil. Might be best to start with the latter.
I have a key for the trunk and seems to turn properly...
Are you holding up the lock handle while you turn the key? Both must be done simultaneously.
Connecting the batteries out of sequence won't damage anything, you'll just get the red battery warning which will clear after the first start, or clear with scanner if it persists.
Nothing will happen after turning the key.
With the key turned 90 degrees, you then pull the latch, and the trunk (boot) should then release and you can then lift it open.
