SL/R230: SL500 2004 won't crank, but was just running well
Old Feb 19, 2024 | 06:34 PM
andetechinc's Avatar
2004 SL500, 2003 S500, 2003CLK430, 2003 ML350, 1961 Etype
Hi I'm a newbie to R230, but have had several other MB's incl. 2003 ML350, and now have 2003 S500 w/ 298k mi.
Just bought a very nice 2004 SL500 a week ago and it was running perfectly with no codes. Then yesterday the ABC light came on so I scanned it, but that is a separate issue to take care of...
The issue right now is that after scanning a few times a "DIAG" window came up on the Comand screen a few times, so I turned the ignition off. Now it won't even crank, but all of the lights come on. The battery is good, it's been on a charger and I had just had it running a few mopments earlier. Is there anything that would disable the starter circuit in that situation?
Great car though!
Old Feb 19, 2024 | 06:58 PM
BTW, the code now is B1829 so possibly fuse?
Old Feb 19, 2024 | 09:04 PM
JettaRed's Avatar
Veteran: Army
The DIAG is normal when COMAND is being scanned. (There are two links. Check the link and the YouTube video.)
https://www.benzworld.org/threads/ba...b1829.3061490/
Old Feb 20, 2024 | 06:59 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Which battery are you charging? If the rear battery is low and the 100A firewall fuse is blown, it won't start.
Old Feb 20, 2024 | 04:34 PM
Thank you.
I charged it overnight through the consumer battery and now it is fine. The ABC red light had also come on and it is now gone too!
