SL/R230: Rollbar light
Old Mar 3, 2024 | 01:45 AM
hhagens's Avatar
2006 sl55$$$$$$
Rollbar light
My rollbar light is on in my cluster, rollbar works fine with console switch and values recognized in scanner, any ideas????
Old Mar 3, 2024 | 09:23 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Do you get a message to raise the roll bar? It might see a problem with the release solenoid which will prevent the roll bar from deploying in an emergency. This would not affect normal raising and lowering.
Old Mar 3, 2024 | 01:53 PM
hhagens's Avatar
2006 sl55$$$$$$
Yes it says raise Rollbar it’s in red message but goes away when raised, but warning stays on in cluster …
Old Mar 3, 2024 | 05:25 PM
hhagens's Avatar
2006 sl55$$$$$$
how would check the solenoid??
Old Mar 6, 2024 | 12:33 AM
hhagens's Avatar
2006 sl55$$$$$$
Where should I
Where should I check and how do I rectify???
Old Mar 6, 2024 | 01:12 PM
brucewane's Avatar
2005 SL600
You need a device to read the stored codes in the car's diagnostic system. SDS/Xentry, Foxwell, cReader, etc.
DIY on these cars is futile without at least a minimal code reader.
Old Mar 6, 2024 | 03:01 PM
MikeJ65's Avatar
There should be at least one code. I've never really researched it, but I assume that it does some check on the release solenoid like it does on any airbag squib. It also relies on a sensor for impending roll over, so a fault there would also be a potential cause.
Old Mar 6, 2024 | 03:50 PM
hhagens's Avatar
2006 sl55$$$$$$
Thanks I will check it out on my Autel maxsys ms808……. Hopefully I will see something other than it’s working (moving up&down) …
