SL/R230: Programming new TPMS sensors
Old Mar 30, 2024 | 09:41 AM
xclens's Avatar
2011 Mauritius Blue SL550
Last year I purchased new tires for my 2011 SL550, and I asked them to switch out all of the TPMS sensors in the process. I don't know if that was a wise choice, but apparently they did not bother copying the old codes onto the new ones. After about 20 minutes of driving I now receive a warning "Tyre pressure monitor" "inoperative - No wheel sensors". Can someone please tell me how I can program the new sensors? Do I need STAR?
Old Mar 30, 2024 | 09:51 AM
streborx's Avatar
Top Answer: 1
G550
The tire shop should have done this for you as part of the installation.
Old Apr 11, 2024 | 11:38 AM
xclens's Avatar
I understand that, which is why I mentioned that in the original post? That is why my question was what is the best way to go forward for me? Can someone with knowledge please let me know?
Old Apr 11, 2024 | 11:58 AM
streborx's Avatar
Top Answer: 1
G550
The best way forward is to return to the tire shop and have them do it. They might have assumed your car would automatically register the new sensors (as some cars do), and they neglected to do it.
Old Apr 12, 2024 | 01:03 PM
brucewane's Avatar
2005 SL600
If the sensors were replaced with ones that use the correct frequency there should have been no problem - the car will pick up the new sensors with no additional actions/programming necessary.
I replaced mine with HUF RDE004V21 sensors when I got new tires, no problems and no additional steps needed. Just had to drive the car for a few miles before they started showing the pressure in the instrument panel.
Old Apr 12, 2024 | 01:08 PM
brucewane's Avatar
2005 SL600
I've seen aftermarket sensors that have multiple transmitter frequencies, but I don't know if they have to be set to the correct frequency during installation or if they just transmit on all at once. I've also seen where Mercedes owners sometimes have issues with aftermarket sensors, which is why I went with OEM (HUF is an OEM supplier to MB).
Mercedes has used 315Mhz and 433Mhz for TPMS, varies by year/model. Mine uses 315Mhz.
Old Apr 13, 2024 | 01:36 AM
xclens's Avatar
Thank you for all of the input! I was perhaps foolish in asking them to switch out all of the sensors, perhaps I should have just asked them to switch out the batteries in the original sensors? If that is even possible? I just figured that after 12 years they were bound to start failing anyways, and since I was putting on brand new tires why not just have them switched out at the same time.
Old Apr 13, 2024 | 06:50 AM
streborx's Avatar
Top Answer: 1
G550
TPMS sensors average 10 years in expected life. Batteries are integrally molded into the sensors and cannot be replaced. Installing new sensors was the right decision. Tire shop should have registered new sensors without having to be asked.
Old Apr 15, 2024 | 06:34 AM
xclens's Avatar
Great answer, thank you.
So is there anyone who knows exactly what needs to be done in order to register my new sensors to my car? If they have the correct frequency, that is..
Is Star needed? They are a well-known local shop and have helped me a lot with my other vehicles, but I doubt that they have access to Star.
I've heard there is supposed to be a little device/computer that can register the correct frequencies, without taking the tire off the wheel, and copy the original codes onto the new sensors?
Edit: Unfortunately for me, if the above is true, I don't have access to my original sensors anymore...
Old Apr 15, 2024 | 08:52 AM
streborx's Avatar
Top Answer: 1
G550
Why are you reluctant to return to the tire shop that installed the new sensors and tell them to fix the problem?
Old Apr 15, 2024 | 10:11 AM
xclens's Avatar
I'm not, I just want to understand what they need to do in order to fix the problem, before I confront them about it. I want to be able to have some backed up knowledge to bring to the table, and TPMS sensors are clearly not something I'm very knowledgeable about.
Old Apr 15, 2024 | 10:15 AM
streborx's Avatar
Top Answer: 1
G550
Understand your desire to now what you're asking about. Just show them your TPMS display that's not registering pressures, and they should be able to resolve it.
Old Apr 15, 2024 | 11:27 AM
brucewane's Avatar
2005 SL600
The sensors need to be the correct frequency for your car. That's all. There is nothing to do in Star/DAS/Xentry, there is nothing to do in the instrument panel, there is no "little device" that needs to be used to register frequencies or codes or anything. Nothing else to do.
TPMS sensors have a built in on-off switch that is operated by centrifugal force. They turn on when the wheel spins quickly enough to activate the switch, and turn back off when the wheel stops spinning. This is to preserve battery life.
You install new sensors and take the car out for a drive. You should see tire pressures appear in the instrument panel after 5-10 minutes.
Old Apr 15, 2024 | 12:16 PM
streborx's Avatar
Top Answer: 1
G550
Tire shops have universal TPMS programming tools. You can buy one yourself online, or check to see if TPMS is included on your OBD scanner (if you own one).
Old Jan 29, 2025 | 07:22 PM
yovenim's Avatar
just looking
Last year I purchased new tires for my 2011 SL550, and I asked them to switch out all of the TPMS sensors in the process. I don't know if that was a wise choice, but apparently, they did not bother copying the old codes onto the new ones' free stranger cam chat. After about 20 minutes of driving, I now receive a warning "Tyre pressure monitor" "inoperative - No wheel sensors". Can someone please tell me how I can program the new sensors? Do I need STAR?
To program the new TPMS sensors on your 2011 SL550, you likely need the STAR diagnostic tool, as the vehicle may require it for proper sensor programming. While some vehicles allow manual resets, Mercedes-Benz models typically need the STAR tool to reprogram the sensors. You can try resetting the system through the menu in the dashboard settings, but if that doesn’t work, visiting a dealership or qualified service center with the STAR tool will be necessary.
Old Jan 30, 2025 | 09:05 AM
mrvedit's Avatar
2004 SL600
Likely more complicated than just connecting a STAR,
Since the tire shop likely installed their preferred brand of universal TPMS sensors, they have to be programmed with a compatible TPMS tool which has to be positioned close to each sensor. It then "talks" to the sensor and gives it an ID which is compatible with the brand/model of the vehicle. There are many brands of universal TPMS sensor and even $600 TPMS tools cannot program them all. I own a Motorsports shop which sells custom wheels and tires for trucks, jeeps and such and so far we have spent over $3000 on various TPMS programmers to handle all the different sensors we encounter.
In short, you have to take it back to the tire shop.
