SL/R230: Ok confused
What do the rear windows do? Do they operate when opening/closing the roof?
Do they move when opening a door?
do they operate when you use the window switch on the door? (open side window, then operate switch again to operate rear window.
The rear windows are controlled by the VariRoof module.
My issue has had me stumped for almost a year summer is coming and I want to get my top fix but my issue starts with my rear windows they will not respond to the door switches, center console switch. RVC module ( they won't normalize ) I'm using a autel 808 scanner and can see I think most of the functions the windows have power a both ends ( motor and RVC ) but there is no signal from the RVC ( I have replaced the RVC & Reaf SAM ) I have checked several grouning points . I can operate the windows with the plug from RVC unplugged
