Passenger side window
Old Apr 15, 2024 | 10:14 AM
APD301's Avatar
2003 SL500
Good morning guys,
I drove to work this morning and noticed that the passenger side window had more noise to it than normal. Got to work and noticed that the window is not in the rubber seal at the top of the door. I opened the door, but the window did not lower as it normally would. I tried to lower it with the button, (both sides), and it did not move at all. Am I wrong by thinking that the window has fell out of adjustment in the track? Also am I correct that this will prevent the top from retracting as well? Where do I begin? Thanks guys.
Old Apr 15, 2024 | 07:44 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R230 forum...
Old Apr 15, 2024 | 07:50 PM
aegea's Avatar
2004 SL500AMG, 2003 SL500 USA
To synchronize windows typically after a battery is disconnected, raise both window switches with all 4 windows topped out. Then hold the 2 switches up for a few seconds.
Old Apr 15, 2024 | 08:01 PM
APD301's Avatar
2003 SL500
I tried that and nothing. Just to be sure, this needs to be done with the ignition on correct? If so, it did not work.
Old Apr 16, 2024 | 09:43 AM
aegea's Avatar
yes, ignition on. sorry I thought it was worth a try.
Old Apr 16, 2024 | 04:08 PM
APD301's Avatar
2003 SL500
No worries. I spoke to a mechanic at the Benz dealership and it’s most like the window out of track. I’ll work on it tomorrow night. Thanks for the response.
