SL/R230: Trunk Actuator
Old Jun 25, 2024 | 08:32 PM
Barak's Avatar
2007 SL550
Trunk Actuator
Hey All,
On my 2007 SL550 the trunk won’t soft close unless i pull the actuator fuse (71, behind passenger seat), put it back in and everything works fine for few days and then again it stops.
i checked for leaks and didn’t detect anything (i sealed leaks about 2.5 years ago and it worked great until recently).
i have no error codes, anyone had this issue before and/or can suggest ideas before i drop 500$ on new actuator?
appreciate your advice!
Old Jun 25, 2024 | 08:44 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
If fuse 71 resets it, 99% chance it is a leak in the system. You should have a code in the PSE module. Are you scanning with Mercedes specific software that will find those codes? The trunk actuator is absolutely the most unreliable part of the car and I haven't seen any indication that the part was ever improved. I just recommend repairing it because the new one is going to fail in a few years anyway. I'm now using the superglue/baking soda repair and it seems to work better than other methods for me.
Old Jun 25, 2024 | 09:40 PM
Barak's Avatar
2007 SL550
thanks Mike, no i don’t have MB SW, just generic scanner, guess i need to open up and listen more closely, the last time it was very loud and clear where the leaks were, i used epoxy which did great job.
Old Jun 26, 2024 | 03:11 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Originally Posted by Barak
Hey All,
There are a lot of points on the actuator that can leak, here is a video of all the points to check, use soapy water to test, also check your pipe lines.
