SL/R230: Some advice please from the Sl Greybeards
Old Aug 19, 2024 | 08:23 PM
rodin66's Avatar
E550 Cab
I test drove a 2003 SL500 a few days ago and it had a few issues that the MB dealer tried to gloss over — I know about ABC / BCM / Soft close trunk / PSE but I haven't heard about these — (1) the display characters (odometer , etc ) were very very difficult to read ( not just in the sun but in shade also ) - It was as if there was a rheostat turned to minimum — Is this a R230 thing ? - II did see on Youtube some gent replace the UV film but I don't think that was the same problem — Ive seen some dash photos on auction sites and the numbers / chars are vivid - Mine were anything but (2) Although then car had a start/ stop button on top of the gearshift - it didn't seem to work and you had to turn the ignition key to stop/start the engine - Is that a "simple and well known issue " — I apologize in advance for my noobiness but I'm drinking from a firehouse on SL500 issues — Thanks ! Mark
Old Aug 20, 2024 | 07:24 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
US market 2003's with keyless go came with cards, the key itself does not enable the button. They can be upgraded, but is expensive and probably not worth it for most people. Dash displays do have a brightness adjustment, but they do tend to have brightness issues. I would either have it fixed before you buy, or plan to live with it.
Old Aug 20, 2024 | 10:34 PM
Tom Manning's Avatar
2005 SL 500 R230
Did you try to rotate the little knob in the dash fully CW? The display is very dull with it turned down.
Old Aug 20, 2024 | 11:16 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
Originally Posted by rodin66
I test drove a 2003 SL500 a few days ago and it had a few issues that the MB dealer tried to gloss over — <snip> — (1) the display characters (odometer , etc ) were very very difficult to read ( not just in the sun but in shade also ) - It was as if there was a rheostat turned to minimum — Is this a R230 thing ? <snip>
Mark, I have the same issue on my 05 SL. As it got worse I changed the sensor and control with minimal improvement. I haven't wanted to spend the additional cost of replacing the clusters so I just live with it. Since the car is at a MB dealer, and he seems to want the sale, perhaps he will change the clusters as a condition of the sale. Good luck!
Old Aug 22, 2024 | 08:21 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
OP: read this, the failed LCD parts can be replaced if you are handy:
https://mbworld.org/forums/sl-class-...l-lcd-diy.html
Old Dec 25, 2024 | 07:18 PM
yovenim's Avatar
just looking
I test drove a 2003 SL500 a few days ago and it had a few issues that the MB dealer tried to gloss over — I know about ABC / BCM / Soft close trunk / PSE but I haven't heard about these — (1) the display characters (odometer , etc ) were very very difficult to read ( not just in the sun but in shade also ) - It was as if there was a rheostat turned to minimum — Is this a R230 thing ? - II did see on Youtube some gent replace the UV film but I don't think that was the same problem — Ive seen some dash photos on auction sites and the numbers / chars are vivid - Mine were anything but (2) Although then car had a start/ stop button on top of the gearshift - it didn't seem to work and you had to turn the ignition key to stop/start the engine Queen ants and ant colonies- Is that a "simple and well known issue " — I apologize in advance for my noobiness but I'm drinking from a firehouse on SL500 issues — Thanks ! Mark
The dim display on your 2003 SL500 could be caused by an issue with the instrument cluster or the dimmer switch. While it's not a typical problem with the R230, it can happen and might require a diagnostic check or a replacement of the display unit. As for the start/stop button not working, this is a more common issue. It could be a problem with the button, wiring, or ignition system, and it's not unusual for the car to revert to using the key to start or stop the engine instead.
