SL/R230: R230 ABC System Compatibility Inquiries
Old Aug 21, 2024 | 09:04 PM
AMGSL63's Avatar
R230 SL63 AMG
R230 SL55 and R230 SL63
Is SUSPENSION STRUT compatible?
I heard that the model changed to ABC+ from R230 SL63 in 2008
It would've been a new improvement
Can I use SL55 SUSPENSION STRUT for SL63
I'm asking because I can't find compatibility for the two models anywhere
Old Aug 22, 2024 | 08:53 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
There are four different ABC struts for each corner. ABC1 (2003-2006) & ABC2 (2007-2012) in AMG and non-AMG versions. A strut from a 2007+ SL55 is correct for an SL63.
Old Aug 22, 2024 | 09:03 AM
yovenim's Avatar
just looking
Is SUSPENSION STRUT compatible bmw workshop dubai?
No, the suspension struts from the R230 SL55 are not compatible with the R230 SL63 due to differences in the ABC systems. The SL63, starting from 2008, uses an updated ABC+ system, making the struts incompatible with the earlier SL55 model.
Old Aug 22, 2024 | 07:05 PM
AMGSL63's Avatar
R230 SL63 AMG
Thank you for your answer.
Old Aug 22, 2024 | 07:13 PM
AMGSL63's Avatar
R230 SL63 AMG
Are you sure SL55 ABC suspension struts are compatible over 2007?
Old Aug 22, 2024 | 07:15 PM
AMGSL63's Avatar
R230 SL63 AMG
I also think SL55 ABC suspension struts
Even if it fits SL63, it's just the same shape
I don't think it's suitable for an improved system.
For the right use, it should be used exclusively for SL63 after 2008, right?
Old Aug 22, 2024 | 09:59 PM
MikeJ65's Avatar
For the US, the ABC changes were for the 2007 model year, not the facelift year (2009). Other countries will have different model designations, but all would have converted around the same time. There is only one ABC2 AMG strut and it was used on the last couple of years of SL55's and all SL63 since they would have all been ABC2.
Old Aug 23, 2024 | 01:03 AM
AMGSL63's Avatar
R230 SL63 AMG
Thank you for your kind explanation.
For example, if you're using Arnott's company or a third-party product
Should I get it for SL63 only?
Old Aug 23, 2024 | 08:44 AM
MikeJ65's Avatar
Not sure what you are asking, but if you are buying a rebuild, get the one cataloged for your car. If you are looking for a used one, the interchange is any 2007+ AMG (SL55, SL63, SL65).
Old Aug 23, 2024 | 04:10 PM
ml320x5's Avatar
R230 2005 SL500, 1952 MGTD, 1973 MGB, 1998 ML320, 2002 X5
In USA, R230
ABC1 2003 to 2006, Electrical connector on top of the strut tower.
ABC2 2007 to 2011, None exist at the same location.
