SL/R230: 2012 SL550 ABC line burst/massive leak
On my “to do” list last winter was proactively replacing the ABC line that’s in front of the engine.Well, I never got around to it and I think it failed.
Fortunately only a couple of hundred yards from my house so I’ll get it onto the lift. For reference, mileage is 42,000.
What I first noticed was the wheel was really hard to turn then I got “ABC malfunction” but error message was white not red.
There’s fluid all over the front of the engine but at a quick glance, I don’t see an obvious failure.
Does the hard steering maybe point to something else? I already (proactively) replaced the accumulators and did a fluid flush/filter two years ago. The fluid is not leaking out of the reservoir and it’s not completely empty.
Bob
Bob
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
ABC line won't affect steering. You might have failed the tandem pump which could take out P/S, or you blew a P/S line and somehow affected the suspension. Maybe hit something on the road, or the belt failed and took out either a P/S or ABC line.
Really? The steering was the first thing I noticed and then the ABC error popped up. All within seconds of each other. The belt is still on.
The pump is drawing from the same reservoir so wouldn’t a leak on either side affect the other?
QUOTE=MikeJ65;9031289]ABC line won't affect steering. You might have failed the tandem pump which could take out P/S, or you blew a P/S line and somehow affected the suspension. Maybe hit something on the road, or the belt failed and took out either a P/S or ABC line.[/QUOTE]
There is one pump, but two reservoirs. The fluids do not mix, it is two separate pumps on one shaft. The only thing I can think is that you had an issue with the pressure valve or an obstruction and got a huge pressure spike which stalled the pump and perforated the line. That is an ABC line.
ok thanks, I'm starting to remove it. I have the valve block end disconnected. Has anyone come up with a tool/shortcut to remove the two torx fasteners on the pump end? There isn't enough clearance and read about jacking up the engine but wasn't sure if that for an ABC II system. What about a compression fitting if I can get a good cut in place?
Bob
Bob
I got the hose off , it's part # A 2303204153. I was able to get the two bolts off (they were a PIA) going to the pump without jacking up the engine or doing anything special. I ground down a T40 to make it REALLY short and used a miniature drive which is about 4" long. They do call this a power steering hose.
The failure was right on top, three pinholes so it wasn't road damage.
2003 SL500, 1997 SL500,1995 E320, 2000 BMW Z3, 1979 Ferrari GTB, 2000 MB C230K
Bob
Bob
Just to close out this thread, I was able to replace the entire line and get the pump end removed without doing anything special.
Just very slowly undoing the T40 bolts using a modified T40 bit (I’ve since bought a shallow set which fit onto a ratcheting wrench and would have save me at least 30 mins). I have the part # above and it is listed as “power steering” but it was the ABC side that was low. The initial symptom was no power steering followed by ABC warning so that leak did affect both sides of the pump.
I’ve put about 25 miles on it and it seems fine.
2007 SL550, 2008 E550, 2011 E350, 2012 Chevrolet Caprice PPV
Ha, had a similar issue with my '07. I didn't tighten the oil filter housing enough when I did the first oil change which shot 5w40 all over the motor... happened down the street from my office I lost all power steering and the engine was smoking heavily... for sure though my tandem pump exited the chat!
