SL/R230: Fuel tank ventilation
Old Nov 13, 2024 | 07:54 AM
Lex350's Avatar
R230 350
Hi,
Does anybody have experience with renewing the active valve for the ventilation of the fuel tank?
when I open my cap from the gas tank, it make a serious noise like it is completely vacuum.
tia
Old Nov 13, 2024 | 08:36 AM
streborx's Avatar
Top Answer: 1
G550
Have you checked the gas cap itself? Some have 1-way check valves that admit air but block gases from escaping.
Old Nov 13, 2024 | 08:48 AM
Lex350's Avatar
R230 350
Thanks for the advice. I bought the car with a replacement cap. I ordered a new one right away!
Old Nov 13, 2024 | 08:50 AM
Lex350's Avatar
R230 350
but I noticed the original one says: ohne luftung
so that’s without ventilation?
do you know which ones have the 1 way ventilation that are suitable?
Old Nov 13, 2024 | 09:19 AM
streborx's Avatar
Top Answer: 1
G550
That would be a ventless cap, but might not be the correct one. If the one you ordered was spec'd as compatible, then vented is likely the correct cap.
