SL/R230: Coding out COMAND - What am I doing wrong?
Old Nov 2, 2025 | 07:10 PM
renncoder's Avatar
2013 Porsche 911 Carrera 4S, 2004 SL55, 2012 Lexus IS250, 2021 Toyota Highlander
I'm finally getting around to getting my R230 roadworthy. I've got an aftermarket radio with carplay so I can't change the clock in the dash. I've got DAS that I used to set COMAND to 'not present' in the CGW and I also set the radio to 'not present' in the instrument cluster but that didn't seem to allow a setting to appear in the instrument cluster settings. For those that have aftermarket radios and have set the clock, how did you get the clock setting to appear in the menu? And what did I miss? It's bugging the hell out of me!
Old Nov 4, 2025 | 12:15 PM
mrvedit's Avatar
2004 SL600
Sorry, no idea what your "but that didn't seem to allow a setting to appear in the instrument cluster settings" means. Are you getting an error code?
I also have an aftermarket radio; it takes some experimentation with the left steering wheel buttons and the "+" and "-" to access the clock and change it. My car is at another location now, or I would write up the exact steps.
Old Nov 4, 2025 | 05:15 PM
renncoder's Avatar
Within DAS, there's a section to do a control adaptation for the instrument cluster. I can't recall the name exactly. I was following this thread: https://mbworld.org/forums/sl-class-...installed.html. interestingly enough, I made a couple of comments back in March. Just getting around to doing it now
Old Nov 5, 2025 | 05:59 PM
renncoder's Avatar
Figured it out.
Go to:
"Control units"
"Information and communication"
"ICM - Instument cluster with maintenance interval display"
"Diagnosis to plant specifications"
"Control unit adaptations"
"Control unit adaptations (variant coding)"
"Variantenkodierung Werkseinstellungen" (meaning: variant coding factory settings)
Scroll down and set "Uhrenverstellung" (meaning: clock adjustment) to "enable" -- It's about half way down.
It's not immediately available. You'll need to force the instrument cluster to restart. In my case, I added Distronic (which I don't have and it was the first one listed at the top of the control unit adaptions section ) and set it to PRESENT. Coded it to the ECU. Changed it back to NOT PRESENT and coded back to the ECU. After that it was available in the instrument cluster settings in the dash. Powering off the car then back on might work but I'm not sure if the ECU truly powers off immediately. I'm sure if you left it for an hour or so, it would have had the same effect.
