SL/R230: REAR ABC VALVE BLOCK
did i blow up an accumulator or has one of the solenoids failed ?does anyone have experienced that?
it would be obvious to diagnose it first but it's raining i didn't want to get wet. i thought of buying a new valve block and just replace it.
https://www.mri-auto-diagnostics.com...ng.Guide_..pdf
The tool is only necesaary if you have the newer (post 2006) cap which is on the left.
The tool is expensive ( ($150-$200) and only does this one task. However, doing the flush without it (if you have the style reservoir that needs it) is alot more difficult and a mess. I would have bought the tool but thankfully mine was the older style reservoir so I didnt need it.
so i usually start a RODEO ? or PITCH or ROLL then with the CAP OFF (connected to a third hose to whatever into a bucket) let the oil OUT then manually add fresh green oil
i just finished watching the AGA flush tool video i think i won't need it but i might buy it that's like 15 liters of oil i can buy with that kind of money
1. Took the car for a 4 or 5 mile run just to get things warmed up suspension wise.
2. Get your STAR connected and ready to go and familiarize yourself with how to get to pitch mode as I dont think it stays completely connected goung from ignition off to started.
2. With the car off direct return line into a 5 gallon pail. I srltarted with a clean white bucket, this way I could see if any particulate was in the old fluid that got flushed out.
3. Get your 10 liters of Pentosin ready to go. Put a large funnel into the top of the ABC reservoir.
4. Have a buddy start the car. Once the car is running you need to pour Pentosin into the funnel as it pumps out.
5. Get into PITCH mode in STAR.
6. Add Pentosin into the funnel. You need to make aure that reservoir doesn't run dry. If you get behind, have your buddy turn off the car until you catch up then start the process again.
7. When you start adding in the last quart you can shut the car off. Be sure to stop the car before you add all your Pentosin in. Save some to top off the reservoir.
8. Remove the old ABC filter from the reservoir. Put the new filter in.
9. Reconnect the return hose to the cap. put the cap back in place.
10. Fill reservoir with additional Pentosin if needed.
11. Pour old fluid from the bucket into the empty Pentosin containers. Dispose accordingly.
the self leveling tool does what exactly? and do you leave in the reservoir? you still need the cap off right?
If your cap is like the one on the right in the picture, YOU DON'T NEED THE TOOL. Don't buy that tool if you don't need it. It's not like you can use it anyway. It's designed for the cap on the left. It won't work. You can buy most of the Pentosin and a new ABC filter with the money instead.
Yes, a sagging rear corner indicates the rear valve block needs a rebuild. I suggest doing the rebuild yourself with a kit, typically $50. Doing the rebuild is easy, getting the valve block out is not.
Looks like I will have to tear apart my valve blocks again.
prior to this i made a stupid mistake; i replaced the SL500 pump with a CL500 pump while the pump was good i had to use a power steering hose hoping it would work i don't think oil was really getting in the system. so i replaced the pump with the correct pump. i did a flush today. i did a RODEO.
i don't know it seems to be working but i can't get past 120 bars during RODEO (the car was coming up HIGHER on the left side than on the right side)
DYNAMIC TEST can't be done since it's not building pressure.
i hardly build up 150.
any suggestions? maybe i should drive it a little bit.
https://mbworld.org/forums/sl-class-...m_content=post
IIRC this smaller block with its valve is available on eBay for $100 or so. I recall a thread from a year ago where the OP replace this pressure valve block to solve his problem.
i managed to get somewhat of a consistent height where i would calibrate to a desired height then save though i was never able to get rid of the ABC yellow warnings.
the pulsation dampener is around 4 years old the only time i had to change pulsation dampener was when it exploded. i've done it twice on this car so far; the first time it was the original one and the second one was a used from junkyard so i decided to purchase a new one from pelican parts.
now i do have a bad banjo bolt eh? part number 0019902163, i have to replace that.
There was at least one report of this pressure relief valve leaking and preventing full ABC pressure. For some (most?) cars it is part number 2203200858 and available on eBay with and without the pulse dampener for $100-$200.
Not trying to throw more parts at you, but personally I would replace that simple part before blaming the pump itself.
what do you call it? a pulse dampener?
- EPC / WIS functional name: pulsation damper
- Hydraulic system description: pressure pulsation damper
- Parts packaging label: air chamber
For the R230 ABC system, WIS and DAS do not use the box label name (“Air Chamber”). Instead, they refer to this component by its functional name: Pressure Pulsation Damper or Pulsation Damper – ABC. This applies to the center/rear-mounted small cylinder plumbed into the rear ABC valve block.
Source, Name Used
OEM parts box, Air Chamber
WIS (Workshop Manual), Pressure Pulsation Damper
DAS/Xentry, Pulsation Damper
EPC (Parts Catalog), Dämpfer – ABC (German for “damper”)
If the spring gets weak or the valve leaks you will not achieve 180 Bar. I don't know if the ABC pump regulates pressure, like a power steering pump does, or if 52B actually regulates the pressure. (If you know for sure, please let us know.)
Also, I've had a number of bad valve blocks and have never found the rebuild kits to help.........when I pull the solenoids, all of the o'rings and TFE backup rings are in nice shape. Although I did hear of a case on this forum of an extruded o'ring that and in that case the rebuild kit fixed it. Don't bother with an "rebuilt" valve blocks that you see, particularly on eBay, because nobody has created a test rig to confirm that the solenoid blocking valves don't leak (Blocking valves trap fluid in the struts when car is off, and thus hold the height positions). I've found I'm better off with a new OE part (big $$), or if you are willing to take the risk of the Remove/Replace labor, then used ones on eBay are a good bet.
Let us know what you ultimately find.
right now i get to drive a little bit then when i come to say a traffic stop then ABC RED Drive Carefully shows up. now this is a warning that ABC is no longer working if i don't have the shocks at their highest, i get ABC DON'T DRIVE CAR TOO LOW so it's dropping.
The Don't drive message tells you the car is too LOW. That will be visually obvious if in fact it is.........wheel will be way up in the wheel well. That could be an ABC Valve Block (The control valve not the blocking valve), a bad strut, unlikely, or a bad height sensor. You can test/check/compare the height sensors in DAS under the ABC section. If the ABC isn't working, then it's "deactivated", and if that's the case, the blocking valves automatically close and the car won't drop or drop very fast. So I don't think the it's not working scenario makes sense.
