SL/R230: ABC Calibration Help
Old Apr 10, 2026 | 10:54 AM
aolexy's Avatar
2005 E500, 2004 SL600
I have rebuilt both my valve blocks. Replaced a solenoid in the front valve block since it was dead. I bench tested each valve with a battery to make sure they work before putting them back in the car. Replaced front right strut since it was weeping and had an error code. Flushed fluid, replaced filter and ran a rodeo, pitch and roll.
The problem is when I try and calibrate height at each corner. The back struts move up and down and the voltage adjusts accordingly. Issue is with front struts, they do not move, and voltage looks like it slowly decreases (front right goes down).
What am I missing here?
Old Apr 25, 2026 | 12:43 PM
MK19's Avatar
Just sold my '11 Porsche TurboS cab for an '03 SL55!
Here's my step by step procedure that I've developed over time (lots of time in it too)
