SL/R230: P2003 (malfunction of secondary air injection (function chain) (p0410))
Attached is a video of what I believe is the air injector running.
Has anybody dealt with this error? What is my plan of attack to resolve this issue.
I found the easiest fix was to disable the secondary air pump in Xentry.
Later when I removed the engine to replace it wish the AMG version, I discovered that the vacuum line controlling the air pump had failed. This vacuum line is under the right side intercooler and has a sharp 180 degree bend in it. It split in the 180 degree bend. I replaced all vacuum lines on both M275 engines with silicone lines. That 180 degreed vacuum line connects to the air pump control valve; I suspect its either that vacuum line or the control valve.
BTW - you only have to lift the intercooler a bit to see an access the line; you can keep the cooling lines connected.
Fortunately I'm in Michigan where there still is no emission testing.
From AI search:
The secondary air pump on a Mercedes-Benz R230 (SL-Class) is an emission control component that forces fresh, oxygen-rich air into the exhaust manifold immediately after a cold start. This process rapidly heats up the catalytic converter, enabling it to reach operating temperature faster and significantly reducing harmful hydrocarbons and carbon monoxide emissions during the initial, rich-fuel combustion phase.
Since your emission test is with a warm engine, even less likely there would be a problem.
Still, did you look for a cracked vacuum line yet? On the M275 its a 3" long line with a sharp 180 degree bend in it.
