SL/R230: Operating retractable top with key
Old Jan 24, 2005 | 10:39 AM
azferrari's Avatar
Lately, when trying to operate the retractable top with the key
(by pressing and holding the "lock" (for top to go up) or "unlock" (for top to go down), it won't work.
I have checked the batteries in the key.....batteries okay. I also make sure I'm pointing the key at the sensor on the door handle.
Any thoughts?
AZFerrari
'03 SL 500
'95 Ferrari F355
Old Jan 24, 2005 | 10:58 AM
LovinMercedes's Avatar
2026 Mercedes CLE53A4 AMG Cabriolet and 2025 MAYBACH EQS680V4
Any thoughts?
AZFerrari
'03 SL 500
'95 Ferrari F355
If any part of the key is working like the door locks or the windows open and close then the key is working and it is the mechanism in the car. If you can't get the key to work at all, keep working on those batteries. Also, try the other key.
Can't imagine it is anyting big. Take it to the dealer.
Good luck.
Old Jan 24, 2005 | 01:45 PM
blueSL's Avatar
SL55 AMG
It's only the infra red element of the key which operates the roof, so that key has to be close, a few feet and pointed directly at the door handle. It's not like the radio unlocking.
Old Jan 25, 2005 | 07:16 PM
carlosfernandez's Avatar
SL500 2003 previous/ E350 2007 actually
Did you find out the reason why the key did not open the roof?
Old Jan 28, 2005 | 05:59 PM
sarb's Avatar
2003 SL500
The key's infrared has to be close [and pointing at] to the door handle infrared sensor. Also if the sensor on the key or the handle is a little dirty it will block it from working also. Good Luck and let us know if it works.
Old Jan 28, 2005 | 11:17 PM
brent951's Avatar
2000/2004 SLK's, 2004 SL 500, 2009 SL 63 & Porsche 944 Turbo
Powerchip Group 93 Gold
What exactly is this? Is this a chip which we can do ourselves or does it have to be sent out. Cost...Performance?
Brent
Belmont, CA
Old Jan 28, 2005 | 11:20 PM
vraa's Avatar
Haha Brent, you are in such a weird place to ask that question.
You have to send in YOUR chip, it gets reflashed, and you plug in YOURS that gets mailed back.
I can't remember cost, but if you want, I can find out pricing for you, just shoot me an e-mail or PM and I'll also see if I can find the pricing of other ECU chips if you want.
Old Jan 29, 2005 | 05:16 AM
Chris 45971's Avatar
2005 SL 500
Az, are you sure that the thing in the trunk is in locked in place? I remember trying to do this a month or so ago from the outside and forgot that I had moved the trunk thing.
Old Jan 29, 2005 | 10:55 AM
FYI, the trunk piece is called the boot and if it were not engaged it would show a warning in the instrument cluster.
Old Jan 30, 2005 | 02:16 PM
jasab's Avatar
SL500 '05
I have have had a similar problem. It seems to be sensitive to how far way you have the key. My car works well with the key about 4-5 feet away.
If the key is close if tends to stop half way down.
