SL/R231: Replace Key Fob Battery?
Old Mar 29, 2013 | 06:16 AM
Daytona-flyer's Avatar
AMG SLS & S coupe
Two days ago I picked up the car after the 10,000 service. The next day (what do you expect) I got the replace key fob battery.
My Corvette's key battery lasted five years.
If the keys battery is dead, will the car still start with the key in the ignition?
Old Mar 29, 2013 | 11:05 AM
AMG SLS & S coupe
I just changed the battery in the key fob and all is well again.
On the first start, the MFD, showed the fob battery low. I restarted the engine and the warning went away. All bow the the electronic Gods.
Old Mar 29, 2013 | 02:23 PM
BenzV12's Avatar
W212 FL
Good to see it worked , a friend of mine said that you can remove ENGINE START STOP button on the dash and start your engine with a conventional way , by inserting your smart key in it's place should key fob's battery goes dead
Old Mar 29, 2013 | 05:04 PM
Gunther's Avatar
1988 560SL (sold); 2001 E430 (sold); 2004 SL500; 2009 CL550
Yes you can remove the button in the dash; but to replace the key batteries you just need to remove the valet key and then within the slot there is a lever to release the cartridge that holds the two batteries. Get them at Radio Shack.
It's the same set up as the key to my CL and SL.
Old Mar 30, 2013 | 05:05 AM
AMG SLS & S coupe
I like the way the fob opens for a new battery. On my '08 Z06, I had to use a dime in a slot and twist it to open, the tab that holds it closed broke.
My big question was, with a dead battery, will the fob start the car when it is inserted in the ignition?
I'm guessing that it's keyless function will not work way before the battery is dead.
Old Mar 30, 2013 | 06:49 AM
jpeardm's Avatar
13 SL550, 14 E63 Wagon, 15 S550, 11 M3, 08 F430 Spider, 12 ML350
yes, you can take the battery right out of the fob and then insert it and it will turn to start the car.
Old Mar 30, 2013 | 08:10 AM
Gunther's Avatar
Yes it will.
Old Mar 30, 2013 | 08:18 AM
AMG SLS & S coupe
Cool.
