SL/R231: Different Front License Plate mount
Super Moderator
Received 3,227 Likes
I hate having a front license plate mounted as it really distracts from the look of the car. Furthermore, the cheap plastic mount from Mercedes just looks nasty and requires drilling the bumper.
But the police here likes giving out pricey tickets for missing front license plates or generally looks for reasons to pull one over.
So here is a slightly different setup that doesn't require drilling the front bumper and is nice and flush
Here are some pics. First the MB mount on our old SL and then the new mount...
2021 Mercedes GLC 43 AMG
I am curious as well, but this morning while waxing my car I realized that the oil cooler is very small and is in front of the intercooler. I would be somewhat concerned with this blocking air flow to the oil cooler. It's hot here in Texas and it appears that this mount position would block about half of the area. Just something to look at.
Super Moderator
Amazon.com: Bell Automotive 22-1-46230-8 Adjustable Mounting Bracket for License Plate Frame: Automotive
If the front license plate is already mounted by MB, it is somewhat too late as the 2 holes are already in the bumper. That can be fixed/painted cheaply...
It looks so much better as the license plate is not bend and tucked in a bit.
Super Moderator
I bought it on Amazon for less than $6 and free shipping via Amazon Prime, then purchased all stainless steel screws at the hardware store (another $12) to prevent rusting. Amazon.com: Bell Automotive 22-1-46230-8 Adjustable Mounting Bracket for License Plate Frame: Automotive
Super Moderator
I know you aren't asking me, but I mounted a similar bracket on a BMW 335i with all thread and fender washers through the grill. It held the plate for the 3 years that I had the car and went with it as a trade-in.
Thanks. I was wondering how to attach the bracket on the grill. The screws may not screw into grill and you need a nut. Did you modify the nut so that it does not pass thru the grill
I hope that helps.
I got two (2) pieces of stainless steel all thread, six (6) stainless steel nuts for the all thread, and four (4) fender washers. I first attached the all thread to grill by putting a nut and a fender washer on one side of the grill and then putting a second fender washer and a nut on the other side of the grill to clamp the grill between the two (2) fender washers. You can put lock washers between the nut and the fender washers if you are worried about them vibrating loose, but I used a little bit of removable loc-tite. Once the all thread is mounted you just put it through the bracket and tighten it with the 5th and 6th nuts.
I hope that helps.
I hope that helps.
I ordered this from Amazon.com and am hoping to have it installed this Thursday...
1 Post
2013 SL550 Designo 2012 Jeep Wrangler lifted 2010 Ford Fusion Hybrid
Why would you need a holder? I would think you could carefully form the plate to the curve and just use bolts and nuts and washers to hold it. My next project
Super Moderator
Seriously though, the solution I chose made it easy to adjust the angle and placement easily without having the plate touch the bumper and be perfectly straight.
On the 2017 model, this will be a new challenge as the bumper is more sculpted and really only looks good without a plate.
I hope that helps.
I hope that helps.
Super Moderator
Wolfman, I have the same mount but I can’t figure out how you got nuts and washers behind the lower grille, say nothing of a wrench. Did you have to disassemble the lower grille to gain access? If so, how? Or another part of the car? Your install is inspirational but frustrating since I can’t figure out how you did it. TIA
When you look at the lower plastic grill, just buy some washers that fit through horizontal width of the grid opening. The get some longer (2" or so) machine screws, nuts and locking washers. Nothing too heavy (No. 6 or 8). Make sure the washer's hole is large enough that the washer can be angled. If you leave the nut at the end of the screw, you should be able to just push the washer through the grid.
That's it. When you tighten it, the washer will lay flat against the grid without the ability to move/slip. Easy to do, more complicated to explain. Hope this makes sense... Make sure that all is stainless steel.
You can also raise the car and unscrew the plastic cover underneath the bumper. Then you have easy access.
Edit. Looks like you have a 63. Not sure which year but the AMG models have a different bumper with a smaller grid. If my method doesn't work, take the 2nd option.
Wow, that was 10 years ago. I don't have any better pics but the install was super easy.
Stupid front plates
Super Moderator
There’s really no getting around how sad a front plate is but at least you didn’t have to drill holes. It’s so stupid that the new digital plates in CA are only for the back. I was hoping for something cool and virtual to get around the front plate thing. I have used the dealer 30 day paper plate for about 5 years in a row now. Back only. I get FAR fewer tickets compared to using the real back plate only. It’s so odd. I’ve only got one , when i was given a parking ticket. But no snark on the expired paper plate. Registration is current obv. It’s esp funny because this car hasn’t been sold for 3 years. Don’t hex me now guys! I’m pretty sure CA can’t pull you over just for that-but I have a story ready to go just in case
The factory license plates setup on the AMG GT model is a thousand times worse than the SL ones. Here is a pic of how those look...
Ugly front plates
Last time we got a car in California, we told them not to install the front license plate holder. I think we needed to sign something so that they are off the hook...
