SL/R231: will these rims fit a '14 SL 550?
Old Oct 11, 2014 | 04:30 PM
Steinhart's Avatar
2018 S 650, 2014 SL 550, 2017 911 TTS Cab, '13 F458 Spider
I'm considering purchasing the following rims and would like to know if they will fit my '14 SL 550? many thanks
HRE 840R:
Front 20x9 ET +34 RIMS 7.0” Inner w/2.0” Outer
Rear 20x10 ET 35 RIMS 7.0” Inner w/3.0” Outer
Old Oct 12, 2014 | 11:52 AM
threeMBs's Avatar
Only MBs - the best or nothing
While offsets you listed are good enough for R231 (at least for 1-piece wheels), the front may require 5mm or even 10mm spacers to clear calipers due to (not the offsets, but) the positioning of the inner spokes in relation to calipers (this "problem" mostly occurs with 3-piece wheels with lips of over 1" - i.e. et30 3-piece wheels I test fitted on C218 (same offsets as R231) cleared (same as R231) front calipers by barely a mm (I ended up using 10mm spacers for "comfort" and looks)).
Old Oct 12, 2014 | 12:26 PM
Wolfman's Avatar
Super Moderator
Agreed to what ThreeMB's said.
I would just recommend looking at pics with that type of wheel on your car. Personally I think the R231 looks better with concave wheels and a small lip
Old Oct 12, 2014 | 02:50 PM
Steinhart's Avatar
these are 3 piece wheels, so would using spacers cause any difficulties with the mechanics of the car or any warranty issues?
Old Oct 14, 2014 | 02:46 PM
Steinhart's Avatar
I'm having the wheels modified by a specialized high end wheel shop locally, Wheel Specialists Inc, they will modify to the wheels to fit properly instead of using spacers.
Many thanks for all your comments!
