SL/R231: SL400 best battery trickle charger connection spot
Old Aug 11, 2015 | 05:47 PM
giovani2's Avatar
A5
Planning my 2015 SL400 winter storage. I am not sure I need to use a battery tender, but... The car will be driven occasionally if the temp gets above 40F and the roads are dry just to charge the battery and move the tires so no flat spots occur. Maybe once a month between November and May, 10 to 25 miles. If necessary, what is the best way to install a battery minder? Will both batteries be maintained? Are the cigarette lighter connections effective? Should I just not worry about it and let it sit?
Old Aug 18, 2015 | 10:43 PM
J1013's Avatar
SL550
Easiest way is to use the alligator clip connection that comes with the different battery chargers. I would connect it to the 2 connections (red sliding piece + terminal) and copper colored ground connection. You can lower the but don't completely close it. This should work fine. Easy on easy off.
Old Aug 19, 2015 | 11:03 AM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
I used this on my vette...very handy..drive away magnet just pulls off..connected to battery tender..
http://www.nakidparts.com/id127.html
Old Aug 19, 2015 | 09:16 PM
Wolfman's Avatar
Super Moderator
Sweet setup!
That said, we had our SL's sit in the garage for extended periods during winter and never needed a trickle charger. Fired up every time
