SL/R231: What spacers have you used on a 2016 SL400/450
Old Oct 2, 2016 | 05:06 PM
Stomachmd's Avatar
2009 cl550
Does spacers affect the ride quality any.
Also does it null and void warranty
Old Oct 3, 2016 | 01:51 AM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
Also wondering if spacers affect tire wear? Seems like they would add camber to the rear tires, all be it slight.
Old Mar 31, 2017 | 06:26 PM
pcasali's Avatar
SL550 2016
Smile
I have a 2016 SL550 and would like to install 15mm front and 20mm rear H&R DR spacers bolt-through. Could anyone help me confirm whether what listed below are correct fitments?
Thank you.
Front Trak+ Wheel Spacers
Part #: 30556659
Rear Trak+ Wheel Spacers
Part #: 4055665
Front Lug Bolts
Part #: 1454502
Sold individually
Thread Size: M14 x 1.5
Thread Length: 45mm
Seat Type: Mercedes Ball
Head: 17mm
Rear Lug Bolts
Part #: 1455002
Sold individually
Thread Length: 50mm
Head: 17mm
Old Mar 31, 2017 | 07:36 PM
pcasali's Avatar
SL550 2016
Originally Posted by ibanezking
Hey guys
The wheels dont look that great on our UK SL400
The fronts dont look too bad - maybe do with 8 or 10mm
But the backs look hidden in the wheel arches........... maybe need a good 20mm out.............
What have YOU used???
Max
Thank you.
Part #: 30556659
Part #: 4055665
Front Lug Bolts
Part #: 1454502
Sold individually
Thread Length: 45mm
Head: 17mm
Rear Lug Bolts
Part #: 1455002
Sold individually
Thread Length: 50mm
Head: 17mm
Old Mar 31, 2017 | 07:38 PM
pcasali's Avatar
SL550 2016
2016 SL550 wheel spacers and lug bolts
Thank you.
Part #: 30556659
Part #: 4055665
Front Lug Bolts
Part #: 1454502
Sold individually
Thread Length: 45mm
Head: 17mm
Rear Lug Bolts
Part #: 1455002
Sold individually
Thread Length: 50mm
Head: 17mm
Old Mar 31, 2017 | 07:41 PM
threeMBs's Avatar
Only MBs - the best or nothing
Above will work just fine.
As an alternative, you could use 3055665 front spacers (R231, unlike R230, do not have front dust caps so "9" is not required) and 40556654 rear spacers (these rear spacers include special bolts to attach them to car's rear hub, then you use your stock wheels' bolts to attach wheels to spacers).
Old Mar 31, 2017 | 09:25 PM
  #32
pcasali's Avatar
SL550 2016
thank you threeMBs. Your suggestion is very helpful to me as H&R does not list any spacers for the 2016 SL550. The last year they provide spacers for is 2015. Can you also confirm that the type and length of the front and rear lug bolts I listed are correct for 2016? Thanks again.
Old Apr 1, 2017 | 07:43 AM
  #33
threeMBs's Avatar
In the US, all 2013-2016 SL550s should be the same. The only caveat is since I've never seen front hub of R231 SL with ABC, I can not vouch that ALL are the same upfront. If your car does not have ABC, then you can use what you posted or the alternative that I provided. If it does have ABC, then you need to know if front has a dust cap - then must use spacers with a "9" upfront. The rear is identical regardless with ABC or not.
Old Apr 1, 2017 | 09:30 AM
  #34
pcasali's Avatar
SL550 2016
thank you for your reply threeMBs. Please forgive me for my ignorance, I do not know what ABC is. In addition, do the 45mm front and 50mm rear lug bolts seem right to you or too long? Thank you again.
Old Apr 1, 2017 | 10:07 AM
  #35
threeMBs's Avatar
Well then you do not have ABC. If you use spacers in your original post, then the bolts in the same post are the ones to be used.
Old Apr 1, 2017 | 11:39 AM
  #36
pcasali's Avatar
SL550 2016
thank you again threeMBs. I do not remember whether I mentioned that my car is equipped with OEM MB AMG 19" wheels. Are such wheels OK with the spacers and bolts are mentioned? Thanks.
Old Apr 1, 2017 | 02:46 PM
  #37
threeMBs's Avatar
Yes, applies to both 18" OEM and 19" OEM wheels.
Old Apr 1, 2017 | 03:31 PM
  #38
pcasali's Avatar
SL550 2016
Thank you very much.
