SL/R231: How Do You Get A SL Up On A Flatbed Tow Truck?
Old Jan 21, 2018 | 07:11 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
If the engine happens to have a problem and you cannot start it you cannot pull the dash lever and unlock the brakes. Turning the key to position one and then pulling on the lever gives you a dash alert that you have to turn the ignition on to unlock the brakes. So if one has a towable engine problem does the wrecker driver winch the SL up onto the flatbed truck with the wheels locked? How does he get it off? What am I missing here?
Old Jan 22, 2018 | 02:22 AM
rorywquin's Avatar
Shanks’s Pony
From the manual -- not sure if this helps......
The towing eye can be used to pull the vehicle onto a trailer or transporter if you wish to transport it.
Turn the key to position in the ignition lock.
Shift the transmission to position .
As soon as the vehicle is loaded:
Secure the vehicle against rolling away by applying the electric parking brake.
Turn the key to position in the ignition lock and remove it.
Secure the vehicle.
Old Jan 22, 2018 | 08:37 AM
Thanks! I had no idea one could shift the transmission without the engine running......
Old Jan 22, 2018 | 01:39 PM
rorywquin's Avatar
Shanks’s Pony
me too..
Old Jan 23, 2018 | 09:50 AM
rorywquin's Avatar
Shanks’s Pony
I have not tried it. Is there an actual P position for the gearbox like the older manual units? Is the P button the parking brake or the gearbox in Park position....or both....??
Old Jan 23, 2018 | 10:50 AM
I do not know and just curious what to do in case I ever need a tow. I am not home where the SL is parked at this time and not capable of trying the directions out till later on in the week.
