SL/R231: R231 SL Batteries & their replacement: A guide
FWIW.
Now you're looking at the scene in the first photo that D49 posted above. Without going any further, it looks like all you have to do is remove all eight T30 Torx screws and the cage will come right off...but, no. Go ahead and remove all eight screws, but then you will find that the top trim piece on the back of the center console (the one surrounding the "accordion") is also in the way, because the battery cage has two sizable nubs on its inner end (the end by the center console) that are captured underneath the side edge of the top rear center console trim panel. No worries, the top trim panel comes off easily by pulling upward along the sides of the panel, starting near the front. There are, I believe, three tabs (front, middle, rear) along each side of the top trim panel that will pull out of their clips as you apply upward pressure. This panel will come off like the top trim panel on the battery cage did...that is, it will tend to hinge upward, front first, as the back of the panel extends quite a way into/under the rear bulkhead trim panel that surrounds the back of it. Once the three tabs on each side of the top panel are disengaged, just pull forward on the panel to free it from the rear bulkhead panel.
Now, for the only semi-P.I.T.A., and even that's doable with a bit of care. The battery cage has to come forward a bit in order for it to disengage from the rear bulkhead trim panel, but there is interference on its outboard rear corner and the forward nub on its inner end. So, looking at the first photo above again, you see the narrow red leather trim strip coming in from the right side of the picture...the long narrow strip that is right underneath the now-removed "accordion" trim panel. There's red light coming out from under it. That trim strip can be popped loose by working it straight out horizontally away from the center console, but the inner rear end of it is hooked on a vertical guide, so it will have to be lifted vertically just slightly to disengage the guide. Before doing so, there are horizontal retaining pins every three or four inches along the length of this strip, a few of which will need to be released so you'll be able to lift the rear end of the strip off of its guide. Once the strip is free of that guide and the the console, you can lift and twist the end of it just enough, while finagling the battery cage, to get it up over the corner of the cage and out in front of the cage. Now you're finally home free. A little more finessing of the cage and the strip, and the cage is out of there. The battery still has a soft plastic cover over it. That cover is hinged along the inner edge, and there are two clips on the outer edge that are easily released by pressing them outward (away from the console) with your fingers. Once they're released, open the cover and it will likely just come off in your hand, as the hinge is designed to disengage from itself. There's your battery...and a lot of fuses!
By the way, I know I read somewhere that someone had removed the rear bulkhead trim panel (the one that runs across the car behind the seats) while doing this project. I have no idea how easy that is to do, but if it's not too bad it might be a better way to go than going through my last step with the console trim strip. It would remove the worry of possibly breaking something while finessing the strip. With the bulkhead panel out of the way, the battery cage would probably come right out, without messing with the trim strip like I did. My explanation of how I dealt with the strip even has me scared, and I've already done it with no problem. It was much easier than it sounds.
I have a decent imagination, but the only explanation I can come up with for MB to have placed an almost-permanent closed cover over this stuff is for the sole purpose of preventing us from checking/replacing our own fuses and/or battery. I'm more pissed about the fuses, myself. If you look at D49's second photo, there is a large green fuse (30A) right near the top of the pic. I don't know what that one is for, but mine had worked its way almost all the way out of its socket, so I set about pushing all the fuses inside there back down into their sockets..and there were only a couple that didn't move. Some fuses are prevented from coming all the way out by plastic retaining bails, but several are not. My car is buttoned back up now, but if I find a longer pigtail for my CTek and head back in there, I'll be opening an access window in the top of the cage so I can at least check my fuses without having to tear apart half of my interior each time.
I hope all this helps someone...
After a search, I found a compatible DieHard at an Advanced Auto Parts for about $220. Wanted them to put it in but they didn't have a way to maintain computer codes. I had heard the same story from other auto supply stores. The result it turned into a DYI. Very easy once I found a neighbor who had a way to keep the system charged. Hardest part was locating the jump posts under the hood. (Passenger side near the firewall. Look for red cap.) Battery change is very easy with the right sockets, 10mm & 13mm.
Point of the story is that I will not hesitate to do it myself again.
